'89 V12 runs like poop unless using 93 octane...
Old Sep 28, 2016 | 09:53 PM
baxtor's Avatar
Originally Posted by JessN16
I have to warn you: I may be on the verge of making an ignorant statement, but...
I don't think I have a Marelli car. I've got a single "ignition amplifier" with LUCAS written on it sitting on top of the driver's side (LH) bank of cylinders.
Jess
p.s.: I'm also watching the "my car is idling rough" thread because mine also has a shake when idling at low-rpm that goes away immediately upon adding throttle.
Jess, Disregard my reference to marelli and fuel strategy jumper. 1989 was point of change for ignition, it may be a good idea to check your timing though.
Old Sep 29, 2016 | 08:10 AM
reichstall's Avatar
yes the timing needs to be spot on for any fuel to burn correct .So if mine will burn 87 I think a 99 should also .You can go to local airport and get aviation grade fuel I think that is 110 now that has to make a difference.
Old Sep 29, 2016 | 08:57 AM
XJSFan's Avatar
My 90 XJS V12 coupe uses Premium unleaded which is 91 or 93 in Wisconsin. It also states below the gas cap to use Premium Fuel...
Old Sep 29, 2016 | 09:13 AM
BC XJS's Avatar
Only if your compression is greater than 12.5:1
Old Sep 29, 2016 | 09:18 AM
Mikey's Avatar
That's not how it works at all.
You'll see zero difference, not to mention that almost all avgas has lead in it which will destroy the catalytic converters in short order.
Old Sep 29, 2016 | 12:40 PM
Doug's Avatar
Make a difference in.....what?
Old Sep 29, 2016 | 12:42 PM
Mikey's Avatar
Emptier wallet.
Old Sep 29, 2016 | 01:08 PM
  #28
Edelweiss's Avatar
My gas gauge clearly states "Premium Fuel Only".
The fill has a sticker on it that says the same.
You can move the jumper to go down to 87, but that simply retards the timing.
Newer cars can retard the timing automatically (no jumper). But that does the same thing.
Old Sep 30, 2016 | 05:22 PM
warrjon's Avatar
In pre engine management systems that employ knock sensors (aka XJS), there is a minimum octane rating. In these vehicles going to a higher octane fuel will have no effect as the ECU can not adjust timing to take advantage of the increased octane. Even in knock sensed vehicles using 110 will have no effect as the ECU will not adjust timing to that extent.
In the Marelli car Jaguar incorporated an ignition strategy link to have the ECU adjust timing for 95RON. We have 98RON available at the pump but there is no difference in performance in my car between 95RON and 98RON. There is however a big difference between 91 and 95 if I change the link.
Old Sep 30, 2016 | 05:27 PM
  #30
warrjon's Avatar
Jess
Hey Jess you need to check all the ignition stuff. If the car is down 1 cylinder you will only feel it at idle once under way say 100km/h on the open road you will NOT feel it. I know this from experience 1 bad plug lead on a trip it KILLED my RH Cat.
Change ALL 12 plugs
Check/change all 13 ignition leads.
As a start.
IanA
Feb 8, 2025 09:54 AM
British Ride
XJ40 ( XJ81 )
Oct 23, 2016 05:08 PM
Wares
Sep 15, 2016 01:32 PM
smgdata
Sep 7, 2016 11:14 PM
