89 XJS V12 rebuild
Old Jun 9, 2012 | 09:36 AM
  #41
ronbros's Avatar
nice to see a TRUE labor of love , warrjon!! i thought that modifications were not legal in OZ. whats up with that?
might another approach to sub frames(and RUST) be just make them out of Stainless Steel, and TIG weld it together!!!!
and i must ask you WHY so much reengineering of the front wheel bearings?
my car is 33yrs old and no problems with axiel play in them.
THX anyway, keep up the good work.
ron
Old Jun 9, 2012 | 03:22 PM
  #42
R44chopper's Avatar
There is a lot of nice engineering going on in this thread and I don't use that word often.
Old Jun 9, 2012 | 05:51 PM
  #43
warrjon's Avatar
ron
Mods here are difficult and I do not know how legal this is. I assume as it does not modify the the original setup it is ok. For eg I can fit larger 4 pot brakes from the HSV to my daily driver as long as came from the same year model. I can not fit Willwood without having it engineered, I also can not go more than 2" wider than the widest wheels that were available from the manufacturer without having it engineered.
It's probably overkill for what will essentially be a road car. My reason for making these was the original bearings had spun on the stub axle, necessitating new axles, I came to the conclusion that as the bearings were a slip fit on the axle without a spacer to hold them they could spin again.
And I need to justify my lathe, lol
Old Jun 11, 2012 | 03:21 AM
  #44
warrjon's Avatar
Finally back together. Now to get the radiator in and steering hooked up and I can fire her up
Old Jul 26, 2012 | 06:09 AM
  #45
warrjon's Avatar
I decided to roll the lips on the guards to accept larger tyres, to my dismay the LH guard split - well you can see from the pic the rust when I just touched it with the grinder, BOY I am glad I bought a rust free car, can't imagine what a rust bucket would be like.
I didn't take photos of the cut out - any way I did cut the metal out and weld in new inner and outer.
My aim is remove all of the bog (bondo for you Americans).
DSCN0034.jpg?t=1343249960
Before being file finished
DSCN0035.jpg?t=1343249279
After File finished
DSCN0036.jpg?t=1343249292
Old Jul 26, 2012 | 06:15 AM
  #46
JameyXJ6's Avatar
Lead? Wow, you don't find too many people around nowadays who know how to work lead! I was taught how to do it eons ago, but never actually DID it.
Old Jul 26, 2012 | 06:19 AM
  #47
warrjon's Avatar
I taught myself, the hardest part is tinning the metal, but I have been soldering electronics for 30 years so I figured how hard can it be to do metal.
A lot harder than I thought but with some perseverance I have learned a new skill. My wood paddles are old wooden spoons works for me
Old Jul 26, 2012 | 06:26 AM
  #48
warrjon's Avatar
Also getting Charice ready for a new coat of paint - and yes the rear end is out of the car again I was not happy with the job so out it came I should have it back in hopefully next week.
DSCN0040.jpg?t=1343249012
Old Jul 27, 2012 | 10:26 AM
  #49
Mish_Mish's Avatar
You have 2 coats on it already, so I are you going to strip her down now, or do the Armenian body shop style triple layer?
Old Jul 27, 2012 | 10:44 PM
  #50
warrjon's Avatar
I am going to strip it bare metal so I can evaluate anything else on the body that needs attention. A big job I know but I have gone this far so I may as well do it right.
I found a bogy repair on the LH front guard above the headlight where it was full of bog and starting to rust above the headlight mount. All rusty metal cut out and I am in the process of welding in a new bit.
Old Jul 28, 2012 | 07:36 AM
  #51
Mish_Mish's Avatar
I feel your pain brother.
Old Jul 28, 2012 | 06:58 PM
  #52
warrjon's Avatar
I didn't take a photo of this before I ground out the bog but you can see from the pic it's been repaired and not very well.
DSCN0044.jpg?t=1343512339
Cut out ready for new metal
DSCN0046.jpg?t=1343512079
New piece welded in this was a PITA with multiple curves
DSCN0047.jpg?t=1343512194
DSCN0049.jpg?t=1343511927
DSCN0050.jpg?t=1343511936
Almost finished just needs final grinding and the headlight box bracket welded back on
DSCN0051.jpg?t=1343512057
Old Sep 9, 2012 | 04:54 PM
  #53
warrjon's Avatar
Time I though for an update. I have been toiling away cutting my TRW front and rear bumper covers to bits in order to make them fit. These were new and supposedly made from original moulds.
New homemade stainless steel and aluminium bumber mounts- these will never rust.
Old mount
I also bout this 6.0L engine for my next years project.
Attached Thumbnails 89 XJS V12 rebuild-dscn0084.jpg   89 XJS V12 rebuild-dscn0105.jpg   89 XJS V12 rebuild-dscn0101.jpg   89 XJS V12 rebuild-dscn0113_zpsb934c99e.jpg   89 XJS V12 rebuild-dscn0060.jpg
89 XJS V12 rebuild-dscn0076.jpg   89 XJS V12 rebuild-dscn0058.jpg   89 XJS V12 rebuild-dscn0057.jpg
Old Sep 9, 2012 | 05:23 PM
  #54
M90power's Avatar
AWESOME! its nice to see a 6.0 swap thats not a V8.
Old Sep 9, 2012 | 10:46 PM
  #55
Flint Ironstag's Avatar
Just drop a running V12 in it!!! Oh wait, thought this was M90's thread
*runs and ducks for cover*
Old Sep 10, 2012 | 01:34 AM
  #56
Greg in France's Avatar
Warrjon
I notice that the cross pipe on the 6 litre has no filler spout, unlike the 5.3. Could you tell me where the header tank feeds into the coolant water system please, on the 6 litre?
I have a possible project for the winter to re-do these arrangements on my 5.3, and would like to know for that reason.
Greg
Old Sep 10, 2012 | 03:07 AM
  #57
warrjon's Avatar
Sorry Greg I have no idea. I bought this off eBay. there are a few differences if you notice there is no temp sensor in the water pump input elbow.
This is an early 6.0L with forged crank the later 6.0's had a cast crank.
Old Sep 10, 2012 | 01:06 PM
  #58
Sarc's Avatar
@warrjon
You are a true craftsman sir !!
I remember a long time ago watching an old friend of mine lead fill the join on an e type between the rear wing and the body........ it was nothing short of art....
Old Sep 10, 2012 | 04:16 PM
  #59
warrjon's Avatar
The rear bar was PITA, it was never going to fit without major surgery. I ended up having to cut it into 6 pieces. Then line it all up screw it in place with bits of wood and then fiberglass it back together. Atleast now it fits really well.
Ripples across the top of the bar without the sides pulled in.
Old Sep 10, 2012 | 11:31 PM
  #60
wrightbenz's Avatar
Warren whoever you are you have too much time on your hands my friend... So many cars to restore why the XJ?
