Adjusting Braking Pawl
Old Apr 1, 2026 | 11:16 AM
Patrick 1989 XJS's Avatar
Default Adjusting Braking Pawl
Is there a way to adjust the rear instide brake pads by adjusting the parking brake pawl without removing the entire output shaft???
Old Apr 2, 2026 | 05:17 AM
Greg in France's Avatar
I think it is inacessible without undoing the four nuts that secure the driveshat flange/UJ to the diff output shaft. Then it is easy:
Old Apr 2, 2026 | 09:33 AM
I removed the drive shaft and now readjusting the pawl. When I was unscrewing the slotted top bolt that holds the two parking brake pads together it started to crank the adjustment sprocket inside the pawl and actually adjusted the pads and corrected the issue. I would not have needed to remove the drive shaft to make the adjustment. Maybe I was just lucky.
VirginiaDave
May 8, 2024 05:10 PM
jjsandsms
Dec 8, 2023 09:21 AM
jaguar51
Feb 17, 2018 03:01 AM
Emkay
Jun 23, 2015 12:51 PM
M90power
Nov 30, 2014 08:04 AM
