Air Conditioner secondary functions question
Old Jun 3, 2016 | 12:01 PM
that guy's Avatar
Default Air Conditioner secondary functions question
Hello,
If the system is empty as mine is, do the other secondary functions still work such as cooling the fuel and the defrost function?
Thanks,
Paul
Old Jun 3, 2016 | 01:29 PM
Daim's Avatar
Originally Posted by that guy
Hello,
Thanks,
Paul
How? How is the air co supposed to cool with no freon? The defrost function will work but no cooling the fuel...
Old Jun 3, 2016 | 01:49 PM
ptjs1's Avatar
Paul,
The Defrost will work but only partly ie it can still blow air at the windscreen but that air won't be dried as it would be if the aircon was working. So it will be much less efficient in clearing the condensation on the windscreen.
Paul
Old Jun 3, 2016 | 01:55 PM
that guy's Avatar
Thanks guys!
Old Jun 3, 2016 | 05:19 PM
John1949's Avatar
My advice DO NOT run the climate control at all including heating , the lubrication for the compressor is carried by the gas , no gas no lube and I might add that a system with air inside it will corrode ,get evacuation and re-gas asap.
Old Jun 3, 2016 | 06:15 PM
Rchiv's Avatar
I agree with John. You can use ordinary heating etc without the Aircon. If there is no gas then the compressor will not engage but it is wise to have it looked at ASAP.
Roger
Old Jun 3, 2016 | 08:32 PM
that guy's Avatar
I am actually inclined to delete the whole system. It is a convertible, and I live in Wisconsin. Air conditioning rarely is something that would ever get used.
Old Jun 4, 2016 | 05:24 AM
Rchiv's Avatar
Hi John, If the gas has gone the oil would still be in the compressor so would not do any harm if the system is not used. If you have a gas leak it is unlikely that the oil will seep ou as well without being seen.
The compressor will only work if there is gas, No gas no compressor, no air con. Even if you select it the system will not operate.
Roger
Old Jun 5, 2016 | 01:16 AM
John1949's Avatar
Hi Roger , I can understand your thinking mate and you are right that most of the oil does stay in the system and around 6 - 7 fl oz remain in the compressor sump when the system is turned off but , to use an analogy , it is like having oil in your engine sump and no oil pump when there is no gas .As far as using heating my understanding of the Jag is that to maintain the heat setting selected , that in combination with the water valve and by blending ambient air and hot air through the A/C system flaps the temp is maintained however if that is not sufficient the compressor will come on unless the heater is on maximum high temp and not on climate control. Roger just had a light bulb moment once again you are right that if there is a safety switch the comp should not come on My Model (78) does not have a safety switch usually on the receiver /drier perhaps the later models may? which will stop the comp from running. It still will need to be evacuated new Receiver drier and recharge to avoid the valves within the comp corroding , I don't think I made that very clear in the last post. I might add that I have never been able to find an oily patch when servicing a/c's many years ago . just a little tip when checking for leaks , using diluted detergent on the fittings is a common and effective way to find leaks but also cover the entire length of the hoses and look carefully for fine bubbles where the gas permeates through the hoses the only solution is replacement hoses or very regular topping up at the least.
Old Jun 5, 2016 | 04:04 AM
John1949's Avatar
Back again , I have just done some more research as I do not want to steer anyone in the wrong direction. Apparently the 83MY had thermal protection and around 85MY was changed to pressure sensing protection.
Old Jun 5, 2016 | 05:59 AM
Greg in France's Avatar
Just remove the power wire to the compressor and the heater will wotk fine with no worries.
Greg
Old Jun 5, 2016 | 09:32 PM
John1949's Avatar
Removing the connection to the comp via the magnetic clutch will stop it from working , it will not stop it from corroding not just the comp but the whole cooling system , I believe compressors are less expensive in your part of the world but even so ! .For those that live in a warm to hot climate where cooling is a must and might be reading this thread , my advice stands get it looked at or DYI if you can , I know that refrigerant is available in the USA in small cans for top up if that's all that is required .I guess this is a personal choice but if its in the Jag I like it to be working the way it's meant to be......John
Old Jun 6, 2016 | 01:18 AM
Great idea. You can remove the compressor, all the pipes, the condenser and the dryer. Your car will run noticeably cooler without the condenser in front of the rad, and the V will be far easier to get at, plug changes in particular will be a breeze.
Greg
xjsman89
Sep 21, 2016 09:55 AM
bullittandy
May 22, 2016 11:48 AM
albjerryg
May 19, 2016 02:08 PM
dtony
May 12, 2016 05:17 PM
scardini1
May 8, 2016 04:39 PM
