Air injection delete V12 5.3
Old Mar 11, 2016 | 09:38 PM
Doug's Avatar
Default Air injection delete V12 5.3
What's the preferred method these days for plugging off the air injection pipe holes?
Cheers and thanks
Doug
Old Mar 12, 2016 | 01:21 AM
Greg in France's Avatar
Doug, I have never done it, but I would tap and plug them. Plenty of grease on the tap and the swarf should not be a problem. The threads do not need to be that deep, either, and some hi temp Loctite. I would be forever worrying if I had anything there not actually mechanically fixed.
Greg
Old Mar 12, 2016 | 05:42 AM
baxtor's Avatar
Cheers and thanks
Doug
Sealed blind rivets from below into manifold flanges. If you use the correct size the head fits in the o ring recess.
Old Mar 12, 2016 | 06:10 AM
Done heaps.
If the inlet manifolds are off, tap the heads, fit a grubscrew, done. Only tap down a few turns, just enough to bury the grub screw.
If the manifolds are still on, whatever fits in that hole, and rivets as described have been good, and the original clamp plates refitted to hold them in place, and to save shortening those 12 studs.
Old Mar 15, 2016 | 04:31 AM
Stoney85's Avatar
JB weld? 2 part metal epoxy
Old Mar 25, 2016 | 03:24 PM
FerrariGuy's Avatar
I used ball bearings that were a bit oversized for the holes, then tightened down the hold-down tabs back over the top of them. Worked fine.
Old Mar 29, 2016 | 01:12 PM
Jonathan-W's Avatar
Brilliant!!!!
Old Mar 30, 2016 | 01:51 PM
Daim's Avatar
Why dont you buy some new intakes? Last time I looked they costed around EUR 35/piece!
Old Mar 30, 2016 | 02:00 PM
Jonathan-W's Avatar
where?
Old Mar 31, 2016 | 07:47 AM
Daim's Avatar
Originally Posted by Jonathan-W
where?
Jaguar... Jaguar Classic Parts At least they cost that a year or two ago...
Old Mar 31, 2016 | 08:09 AM
44lawrence's Avatar
Why would anyone buy new/other manifolds to plug the air injector hole's ? Use any of the methods mentioned above, their easy & free.
Lawrence
Old Mar 31, 2016 | 08:17 AM
Doug's Avatar
Lawrence
I've put an $8000 cap on this project so I won't be buying new 'anything' unless necessary.
Old Apr 2, 2016 | 04:56 PM
J_C_R's Avatar
I followed the "book" suggestion, pounded in some lead-coated nails as Palm suggested, three years later and no problems.
John
1987 XJ-S V12
apachegogo
Mar 16, 2023 08:37 AM
rsq911
Mar 13, 2016 05:30 AM
Chuck Schexnayder
Mar 12, 2016 10:21 PM
Pilotman11
Mar 11, 2016 09:26 AM
RobinGa
Mar 10, 2016 02:00 PM
