Air pump delete Qs
Old Jan 25, 2017 | 05:05 AM
BradsCat's Avatar
Greg, those look awesome. A bit pricey but what isn't these days.
Your post got me to poking around on the internet some more. I found Summit Racing
-Search
- Part type
== Plug fittings
There are a zillion options. So maybe a 5/16" x 1/2 plug with "o" ring tapped into the hole would work?
Not sure if this is a viable route. Appreciate comments.
Old Jan 25, 2017 | 06:06 AM
JayCee's Avatar
Originally Posted by BradsCat
That does look much easier than it was sounding and I see exactly what you mean with not having to take the manifolds off. Maybe I won't need to wait until next winter to do this.
I've never "tapped" anything so am not exactly sure what is needed or involved. Once you had the screws thru the holes did you grind off the threads to make ends smooth to fit into the air rail hole?
Tapping the threads isn't difficult. If not sure, just google it. I used 5/16" - 18. I just rounded off the bottom half of the threads with a dremel to fit the manifold hole.
...Jimmy
Old Jan 27, 2017 | 07:15 PM
JayCee's Avatar
Just installed a new V-belt for the AC compressor. I could not find the Bando so I picked up Durolast 17440 at Autozone. I unbolted the compressor, tilted it forward, slid on the belt, bolted the compressor back down, and the tension is perfect! Job took about 10 minutes. Loosing the pump (and auxiliary crap) really cleaned up the engine.
Anyone know what engine codes will be generated by pump removal, how to stop them etc. ?
...Jimmy
Old Jan 27, 2017 | 07:23 PM
BradsCat's Avatar
On my '87 there are no codes so its easy to ignore them. haha
Old Jan 27, 2017 | 07:44 PM
JayCee's Avatar
Wise ***....I like you!
Cheers...Jimmy
P.S. I just ignore engine codes anyway.
Old Feb 2, 2017 | 12:10 PM
Dr Quail's Avatar
I pull the rails off and place alloy rivets (round head top) same dia. as holes with a VITON RING attached and replace the clamps and torque down 10pdsi. no muss no fuss........The end pipe at the back is capped off. Best, JW
rf69
21
Sep 22, 2016 09:32 AM
Daim
Sep 17, 2016 03:35 PM
AllblueACR
Sep 14, 2016 12:15 PM
billysiv
Sep 13, 2016 08:11 AM
RonaldP
Sep 8, 2016 08:58 AM
