Is an AJ6 Engineering ecu worth something?
Pop it up for sale, I expect someone may be interested, and it will have value. It has several dates that help verify its good, however I've had no luck buying 2 used (working condition) ecus. Both stuffed, so I had orginal repaired.
Logically, both.
ECU DAC3831 is corresponding to a Lucas 8CU unit put in Jaguar XJS early 3.6 between 1983 and 1987.
Mine is working very well and I’m hardly looking for a Lucas 8CU modified by Roger Bywater (AJ6 engineering).
My Jaguar XJS is a 1986 with the manual tranmission too.
She's running so badly, too poor ou too rich, depends.
I have to send and ECU to ATC Drive Train or find a ECU already passed by AJ6 Engineering (Roger Bywater).
I repeat that I'm very interested SteveM to buy your ECU : contact me by mail if you still have it in hand : deconihout8@gmail.com
