AJ8700 will not accept code
Old Apr 30, 2018 | 11:09 PM
Lesbrough's Avatar
Default AJ8700 will not accept code
I bought an AJ8700 from Jerryjag two years ago and it's been great. After disconnecting the battery for winter storage it needed the security code which I had and entered it and it worked fine, same again last spring. However this year it stays on CODE and will not accept the security code. It just "beeps" after the last number. I know the number I entered is correct as I have the card that came with the radio, and it always worked before.
Anyone had the same? Any ideas? ANy workarounds? Any help appreciated as I replaced a modern unit (which I still have) but I really want my car to be ORIGINAL!
Old May 1, 2018 | 12:49 AM
Jagboi64's Avatar
A quick search came across this on a vintage radio forum:
RADIO UNLOCKED, problem was with Jaguar factory manual. What it didn't say was "hold each number in for 1 second and observe security lamp for flashsing" You can't just punch numbers in.
Old May 1, 2018 | 06:40 PM
Lesbrough's Avatar
WOW - I can’t thank you enough - it worked! A comment for anyone else that has the same problem is to disconnect the battery again to clear everything. I guess I was slower entering the code in previous years: now I am older I must be more impatient :-)
Jaguaforums rocks!!!
franklorea
Jul 10, 2017 05:40 AM
Mike Beda
Sep 14, 2016 10:16 PM
e21pilot
Jul 20, 2014 05:13 AM
Probesport
Feb 18, 2013 08:41 AM
