Alternator coming out Thursday I hope... any tips??
Old Feb 26, 2018 | 04:23 PM
944xjs's Avatar
Default Alternator coming out Thursday I hope... any tips??
got my refurb alternator last week and finally have a couple days off to put it in. Are there any tips or tricks? I'm hoping it can all be done from the top? Cant wait to play with the belt adjusters again!!
Old Feb 26, 2018 | 11:03 PM
Daim's Avatar
I always thought it was easy access. Remove the air filter Boy and you should have it out in a few minutes.
Old Feb 26, 2018 | 11:35 PM
944xjs's Avatar
I'm in the USA so I've heard the air pump is in the way and needs to come out too?
Old Feb 27, 2018 | 12:58 AM
v1rok's Avatar
Yes, you must remove air pump too (and the belt that drives it)
Greg in France's Avatar
If you have the air pump, it will be in the way, and even if you could somehow get the alt out with it there, it will be far easier with it removed. The adjuster and belt has to be under from under the car, then the alt lifts out upwards.
Old Feb 27, 2018 | 02:58 AM
I usually remove more than needed, we Aussies are a special lot.
My way the first time:
Air cleaner cover and backing off.
Air pump off, in the bin, was not going back.
RH radiator hose off.
Fender cover installed, then leaned over the RH fender, and simply reached down and undid the lot from the top.
Lifted out, and all in 40 minutes that first time.
Bear in mind I am physically challenged, and getting all the way don to get under the car is a major task at best, so I work the other way where possible.
Now, with no air pump, thermo fans, 10 minutes tops, to have it out.
Old Feb 27, 2018 | 07:28 AM
Daim's Avatar
Forgot about the pump! Mea culpa!
Old Feb 27, 2018 | 10:12 AM
sidescrollin's Avatar
Honestly the worst part is the stupid flat-by-flat work on the tensioner.
I recall fiddling with a bracket bolted to the engine block, maybe that was the air pump bracket? And then I think a bolt on the alternator or air pump required an extension where you have a ratchet near the air cleaner to clear (remove filter box).
A couple of tedious things but its not that big of a deal. Clean the connections while you are there!
Old Feb 27, 2018 | 10:58 AM
944xjs's Avatar
Thats good to hear it doesn't take that long... course I'm from the luck of, oh there's 3 bolts... 1 of them is rusted and getting stripped. Turns your whole day into an event. Ha
i hate those tensioners!!!! That really is the thing I'm looking forward to least
Old Mar 1, 2018 | 03:58 PM
944xjs's Avatar
Ok so I've almost got the alternator out. Really not bad even with the stupid air pump having to come out. Question.. I already eliminated my air rail so I'm thinking just keep the air pump out... but what belt would I need??
Old Mar 1, 2018 | 10:05 PM
944xjs's Avatar
Ahh screw it, I just tossed it all back in. Was really quite easy. The worst part of the whole thing is those awful belt tensioners! I hate them! All back together and hurray it works!
14.3v at idle. Car sounded stronger right away and the headlights and dash etc were all brighter. Phew
Pork Chop
Apr 12, 2017 02:35 AM
Bruce H.
Jul 7, 2012 08:17 PM
His_Nibbs
Nov 11, 2011 12:57 PM
j_bond
Nov 13, 2010 05:56 PM
