Antenna
Old Aug 9, 2020 | 08:03 AM
Chap1958's Avatar
Default Antenna
I've been looking around for a replacement for my antenna. My car came with a non-powered one that was not hooked up to the radio. There was an older aftermarket one in the trunk as well, and that was not working either. Any thoughts on this eBay one or sources for a replacement?
https://www.ebay.com/i/293181571042?...2Cchnl%3Dmkcid
Thanks, Chap
Old Aug 9, 2020 | 08:59 AM
Doug's Avatar
It'll probably work fine.
Over the years I've installed a few generic/universal power antennas in old cars, including Jags. Typically a bit of ingenuity is required to mount 'em firmly, but no big deal. Wiring is generally easy as well.
What can be a problem is where the antenna pokes thru the body.
XXX-antenna kit, whatever it might be, may not have the right combination of bezels and gaskets to conform to the contours of the the body
Old Aug 11, 2020 | 08:20 AM
sacara's Avatar
Doug,
Do you have actual recommendations for an antenna, one you used and is as plug and play as it could be?
Thanks,
Dorin
Old Aug 11, 2020 | 08:34 AM
Doug's Avatar
Originally Posted by sacara
Doug,
Sorry, no. Too many years have passed and my memory isn't what it used to be
oldjaglover
Dec 25, 2024 04:33 PM
Beep777
Jul 13, 2018 03:43 PM
Richy_T
Mar 20, 2012 02:33 PM
acooper2751
Oct 18, 2008 06:01 AM
