Anyone want to trade a 2.88 LSD for my 3.31?
Old May 8, 2013 | 07:18 AM
Untame's Avatar
Default Anyone want to trade a 2.88 LSD for my 3.31?
I've got a 3.31 gear set on a freshly rebuilt Salisbury LSD. I'd like to swap out for a 2.88 with the Salisbury LSD. Anyone have a good 2.88 ring/pinion and LSD carrier set you'd be interested in trading?
If I understand correctly, the 2.88 crown/ring gear is a "thick" gear and the carrier is different to accommodate this.
I need the higher gearing for a road race car I'm building. Thanks.
Old May 8, 2013 | 07:43 AM
Mish_Mish's Avatar
I have non LSD 2.88 in very good shape.
Old May 8, 2013 | 12:50 PM
JameyXJ6's Avatar
I just bought a parts car so I have an extra set and have been looking around for a set of lower gears like that!
Old May 8, 2013 | 01:19 PM
Untame's Avatar
Call me at (608) 484-2484. Thanks.
Old May 8, 2013 | 04:13 PM
JameyXJ6's Avatar
I'll call you on my way to work tonight!
Old May 9, 2013 | 01:16 AM
calvindoesntknow's Avatar
damn I think the 331 is already gone haha
Old May 9, 2013 | 03:50 AM
JameyXJ6's Avatar
LOL...yeah, it's pretty much a done deal, I just have to pull the one off the spare car.
Old May 9, 2013 | 10:33 AM
its all good, thinking of rebuilding with an.aftermarke posi for mine. maybe 4.09
Old May 14, 2013 | 10:09 PM
Untame's Avatar
According to this (XJ-S Final Drive) the Salisbury was only in 2.88:1 from 1982-1985. However it also says that the Dana 44 was used from 1985-1987 and the GKN Power Lock was used from 1987 on.
I'm thinking that I really should stick with a Salisbury LSD to make sure everything fits in our diff case just right. Is it hard to find 2.88:1 carriers/pinions from 1982-1984ish?
Old May 15, 2013 | 03:00 AM
JameyXJ6's Avatar
Mines an 83, we should be good! But does anyone know how to identify these by sight?
Old May 15, 2013 | 03:53 AM
Greg in France's Avatar
The GKN powrlok and the Salisbury are the same, I beieve. The DANA is different. The DANA has three bolts holding the output shaft flange to each side of the diff body, the Salisbury has four. The DANA has no drain plug, just a fill plug, and usually the Salisbury has a drain plug.
Greg
Old May 15, 2013 | 06:24 AM
Untame's Avatar
Great! For some reason I had in my head that yours was an '88.
BTW... the Salisbury diff case has a 5-bolt axle flange.
Old May 15, 2013 | 06:47 PM
ronbros's Avatar
my 1978 has a drain plug-?
4 bolt axle flange.
Has Jeep 3.73 gears in it, works fine on hiway in 700R4 over drive, gives me a 2.60 final, all is good!
just simple old fashioned hot rod stuff.
Old Jun 25, 2013 | 04:49 PM
Untame's Avatar
Thanks, Jamie, for a smooth trade!
Old Jun 25, 2013 | 06:57 PM
JameyXJ6's Avatar
Lol...smooth? I really goofed with that spray foam! Lol, hope it works out for you!
Old Jun 25, 2013 | 09:10 PM
Untame's Avatar
The "trade" was smooth... getting it out of the box took about an hour.
Old Jun 26, 2013 | 03:36 AM
warrjon's Avatar
The GKN and Dana have essentially the same internals. Jeep Dana 44 parts will fit the GKN diff. There are a few differences but these are all easily overcome.
Jag diff uses 7/16 crownwheel bolts Jeep 3/8
The pinion flange is different.
Thats it.
Old Jun 27, 2013 | 08:07 AM
ronbros's Avatar
if you need more lock up in the jag dana, clutch plates from chevy corvette 59-62, have the bellville spring plates that add more grip to the power lock LSD. i have them in mine,and it does work quite well.
but keeps you on your toes in wet weather! but great for drifting sideways(showoff).
all started with DANA USA. darn yanks get around!
robbing
Mar 5, 2024 10:51 AM
Delta66
Oct 4, 2015 05:40 PM
JAMES1944
Sep 29, 2015 11:58 AM
yarpos
Sep 27, 2015 06:14 PM
