Better MPG after eliminating leaking oil cooler hoses?
Old Jan 24, 2018 | 07:17 AM
Vee's Avatar
Vee
Default Better MPG after eliminating leaking oil cooler hoses?
I have a 96 XJS with the AJ16 engine. ive been struggling with poor mpg’s. After throwing a ton of parts and getting the injectors cleaned, I suspected issues within the ECU. I sent a spare out to a shop for refurbishment, have not got it back yet.
In the meantime I’m starting to attack some leaky areas in the engine bay. First thing to go was the heavily leaking oil cooler lines along with the cooler itself. I put in the bypass part in its place.
After a few commutes to work, it seems my mileage is back to where it should be. I’m seeing an average of above 20.0mpg whereas before I was struggling to get past the 16s.
How could the removal of leaky oil cooler lines affect my mpg’s, or do I need to continue watching for a return the norm?
Old Jan 24, 2018 | 07:33 AM
Doug's Avatar
I can't easily think of any direct connection between the two.
If I s-t-r-e-t-c-h my thinking a bit....
Bypassing the cooler makes the engine run warmer which gives better fuel economy...but a whopping 4 MPG? I dunno
Old Jan 24, 2018 | 09:58 AM
Vee's Avatar
Vee
Anything to do with heavily leaking hoses?
The crimps were failing on both ends as well as well as the o-rings.
If I parked the car and ran the engine for 10 minutes I would have oil on the floor. Any possibility there’s some kind of pressure loss in the engine that would cause trouble.
Old Jan 24, 2018 | 11:00 AM
Daim's Avatar
Personally: I doubt it.
Old Jan 24, 2018 | 11:42 AM
sidescrollin's Avatar
How was the data gathered? Were both only based on the same number of commutes to work with the same traffic and the same weather?
Maybe the previous was over a longer period of time and included some short trips to the store, in different weather, or in slower traffic? Without the exact same conditions I doubt the info is very useful or worth comparing.
Old Jan 24, 2018 | 06:36 PM
Vee's Avatar
Vee
Data is similar. Its been the same ride to and from work, in the summer, spring, winter and spring. Freezing cold, boiling hot, the numbers seemed to remain the same.
Right now I am averaging 20.2mpg according to the trip computer. Previously I was struggling to get to 17mpg. Mostly highway miles, some traffic.
My LTFT is still pegged at 7.8, but it is something I will check in on again. I suspect if something really did change, the trim should fall.
Old Jan 24, 2018 | 07:00 PM
Andreas Schmieg's Avatar
20 mpg??? I don't even get that when I push mine.
Old Jan 25, 2018 | 06:15 AM
Vee's Avatar
Vee
Keep I. Mind, it’s the AJ16, 6 cylinder, not the 12.
if I were to drive straight highway miles, I should be able to average well above 24. I have done it in the car.
Old Jan 25, 2018 | 09:19 AM
Where I used to live (totally different speeds) I had my V12 up to 18 going to and from work, totally stock (using the odometer to calculations). It is possible.
I suppose the engine could just be running hotter, as doug said, but I didn't think the oil cooler was doing that good of a job. Wonder if its worth upgrading.
Old Jan 28, 2018 | 12:14 AM
VancouverXJ6's Avatar
I see your in the US so that is good for what I'm about to suggest... regardless of what the actual cause is regarding your poor mpg I'd like to strongly recommend two products which should give a noticeable improvement.
Archoil 9100 oil friction modifier
and
Chevron Techron concentrate
I can't say enough about Archoil the difference in performance and the overall reduction in wear/heat is well documented in everything from racing to industrial applications, and the concentrated techron injector cleaner is literally the best bang for your buck - I have family in the US that mail me the product because it works better then anything here aside from LiquiMoly.
My V12 XJS was night and day difference between synthetic oil and archoil, I also managed to clog my fuel filter in a week after a few rounds of techron. After replacing filters the difference in performance and milage was substantial as I was getting 4-6mpg before and 12+ after which isn't terrible for a 30 year old v12.
Used the same process in my 89' XJ6 to and averaged 24mpg on mountainous hwy conditions. Sometimes its just one clogged injector that needs a cleaner blasted through it at max PSI.
Staatsof
42
Jul 7, 2019 09:39 PM
new mexico
Jun 4, 2017 02:33 AM
new mexico
May 22, 2017 09:43 PM
Vee
Jan 28, 2016 02:31 PM
Roger95
Dec 16, 2015 09:09 AM
