Rear anti roll bar
Old Jan 27, 2018 | 07:59 AM
brinny's Avatar
Default Rear anti roll bar
With regard to the rear anti roll bar would anyone know if replacement drop link bushes are available as opposed to replacing the whole thing.? I have looked for polybushes and can’t find a replacement, is it possible to make your own? Or does anyone know of uk suppliers. Don’t really want to buy new from jaguar at 55 pounds plus vat and postage each side or cheapo that won’t last 2 minutes. Any help with suppliers etc gratefully received. All uk based ideally. Many thanks
Old Jan 27, 2018 | 08:09 AM
44lawrence's Avatar
You can replace the whole drop link with adjustable heim joints .
Old Jan 27, 2018 | 08:23 AM
Greg in France's Avatar
Manners and John Gordon's stuff is usually pretty good Brinny. Try these:
Manners 31 quid
http://www.jagspares.co.uk/Manners/p...rtno=C42907%2A
or the 35 quid opiion
https://www.ebay.co.uk/itm/JAGUAR-RE...-/121034862242
Greg
Old Jan 27, 2018 | 09:34 AM
Doug's Avatar
The part number is C10940
I replaced them and I'm pretty sure I was able to buy new from Jaguar....but without checking my notes I'm not 100% certain.
Old Jan 27, 2018 | 09:36 AM
Doug's Avatar
For poly bushings....
https://www.terrysjag.com/product/C10940TJP.html
The drop links are the same use on the XKEs. That opens up more searching possibilities
Old Jan 27, 2018 | 12:18 PM
Jagboi64's Avatar
C10940 has been used on lots of cars over the years. If you want poly bushes, talk to Rob Beere in Coventry, I believe they have them.
Old Jan 27, 2018 | 12:23 PM
Doug
I have part number C42907 from my searches. These are available from Jaguar but as huge cost as the OP mentioned. My links are this same part number but miles cheaper.
Your number is listed by JCP as a front ARB drop link for the Daimler limo.
https://www.jaguarclassicparts.com/uk/part/C10940
Greg
Old Jan 27, 2018 | 12:37 PM
Jagboi64's Avatar
It's just the Metalastic bush. The drop link assembly with the bushes installed is different.
Old Jan 27, 2018 | 01:36 PM
Doug's Avatar
Right, C10940 is the bushing, #26 in this illustration but used on many models besides the limo
https://www.jaguarclassicparts.com/u...ember-assembly
C42907 is the entire link, #6 in this illustration
https://www.jaguarclassicparts.com/u...tre-sportspack
Old Jan 27, 2018 | 03:14 PM
Thanks Doug. So if the Op has the metal bit already, all he needs to do is buy the rubber, which is cheap.
Greg
Old Jan 27, 2018 | 03:19 PM
Doug's Avatar
Greg
Right. And they're a snap to install. A bit of Syl-glide and squeeze 'em into place with your bench vise.
Removing the old ones is what takes the time
Old Jan 28, 2018 | 03:30 AM
brinny's Avatar
That’s a big help thank you all.
rocklandjag
Mar 27, 2021 09:48 AM
XJ8JR
Oct 21, 2015 12:04 PM
dennisw
May 30, 2013 12:22 PM
740i
Aug 6, 2010 11:11 AM
ferret
Jan 28, 2010 02:22 PM
