Blue.White fuel vacuum switch -- how to test it?
Old May 13, 2017 | 11:05 AM
v1rok's Avatar
Default Blue.White fuel vacuum switch -- how to test it?
I assume this is the Blue.White fuel vacuum switch:
How do I test that it works as intended?
Old May 13, 2017 | 11:18 AM
Greg in France's Avatar
My understanding of the system is as follows (always subject to correction):
The switch should pass current when NO vacuum is applied. Disconnect the two connectors from the loom. If you use a test lamp on the connectors with the car not running and vac line removed, the light should light. This is the equivalent of WOT and the switch earthing the circuit thus making the ECU go to a rich mixture. This is to avoid any leanness at WOT and consequent piston problems.
If you keep the test light circuit going and re-attach the vac tube and start the car and leave it at tickover, the light should go out as the vac opens the switch and allows the fuelling circuit to the ECU to function normally.
If you want to test at exactly what pressure the switch operates, then you need to test with a vac apparatus of some sort with a manometer attached.
Old May 13, 2017 | 11:51 AM
Doug's Avatar
I vacuum pump with gauge would do the trick, I'd think
Mityvac
Besides testing for operational/non-operational it would be helpful if we knew at what point the switch is intended to close. Does anyone know? I don't recall seeing a specification anywhere.
I'll throw out a guess and say 5 in/HG
Old May 13, 2017 | 12:22 PM
v1rok's Avatar
Sorry, didn't quite get the first part. (Probably just misinterpreted.)
If I disconnect the two connectors, where do apply the test lamp? To the connectors on the side of the fuel vac switch? Or to the connectors from which the switch was unplugged? If the former, how would lamp could turn on, because once disconnected the switch should not have any source of electric current, right?
I am sure I am missing something
Old May 13, 2017 | 12:43 PM
Doug's Avatar
I assumed Greg was referring to a self-powered test lamp; 'continuity checker'.
An ohm meter would work as well
Old May 13, 2017 | 12:55 PM
v1rok's Avatar
I see. I don't have a self-powered lamp tester at the moment.
Will try with DVM/Ohnmeter
Thanks all!
Old May 13, 2017 | 12:57 PM
As Doug, explained, my idea was that you apply an external 12 v source to the two disconnected terminals coming from the switch.
Old May 13, 2017 | 02:42 PM
xjsv12's Avatar
The switch get 5V. 12 volt will be a problem for the ECU
Old May 13, 2017 | 02:53 PM
Doug's Avatar
The switch simply sends a ground signal to the ECU.
Old May 13, 2017 | 03:12 PM
The switch will be disconnected from the loom when you test it, as the connectors are disconnected. So the ECU will not see any of the test voltage
Old May 13, 2017 | 09:12 PM
Disconnected from the loom, 100%.
A standard medical sytringe (about $2 at the local pharmacy minus needle),medium size, works just fine.
NO/lo vac = continuity.
Vac applied = Open circuit.
Doug's 5" is pretty close from memory.
I drove mine with vac gauge attached, and threaded thru the door window, and noted the vac readings at certain driving conditions, then adjusted that switch to open/close when I wanted it to.
A "T" in the syringe line, vac gauge attached, and it was a simple procedure to get it where I wanted it.
Old May 14, 2017 | 01:13 AM
Grant
How did you adjust the switch, please?
Greg
Old May 14, 2017 | 03:37 AM
Aussie secret maaaaaaate. Lucas special tools required.
I will do a detailed write up tomorrow, too bloody cold in the shed now, and email to you, and post on here obviously.
Old May 14, 2017 | 06:19 AM
JigJag's Avatar
There was a discussion on JL where the original switching point was determined to be 4 in hg. With age this drops lower with 2 in hg switching not uncommon. This was considered a "dangerously" low switching point. Failure of the throttle WOT microswitch in addition to a 2 in hg or less switch point on the vac WOT could result in no WOT enrichment which apparently leads to bang/smoke/cursing.
An available replacement part was located.
DavetheLimey found a direct replacement switch and I've purchased and installed one. It is rated @ 4hg. It can be purchased from Summit Racing, part # SWW-77343-04. This was a very important find, as the original EAC-4371 is no longer sold. Thanks to DavetheLimey for sharing his research.
--Wolesley
Old May 14, 2017 | 08:07 AM
Doug's Avatar
--Wolesley
As I recall from other discussions not all V12s used the redundant enrichment switches, Jaguar apparently deciding only certain variants/markets would benefit from having them.
Am I correct?
If so, I'd be happy with just the mechanical switch.
Old May 14, 2017 | 09:08 AM
Doug,
Some markets had this Blue/White switch, some had the older PreHE style switch, some had the mechanical only, as you have noted. I think it was dependant on the emissions junk required.
It was/is a fairly safe switch, coz if the vac fails, hose falls off, diaphragm splits, the valve "sees" NO vac, so the contacts close, the ECU goes into Open Loop, and richens the fuel by about 10-15%ish.
The biggest issue with them is some need the vac to drop waaaaay too low to close the contacts, so the ECU stays in Closed Loop when a richer mixture really is needed. At some point of the loud pedal depression, the mechanical switch takes over, and all is OK.
Adjusting that switch to suit your engine, and your driving style, is possible, and as I said, I will write this up tomorrow, with pretty pictures. I have a spare switch in the stash.
Old May 14, 2017 | 09:17 AM
Am I correct?
You are Doug. USA cars had the vac switch and a microswitch on the rear of the capstan. They were wired so both or one would do the job. UK cars just had the vac switch. I believe the redundancy was because of the low octane number of US unleaded fuel at the time of manufacture.
Old May 15, 2017 | 07:25 AM
As promised, here ya go.
V12 Full Fuel Switch adjustment.pdf
