Brake fluid only one side
Old Jan 19, 2021 | 04:49 AM
BeepBeepYeah's Avatar
Default Brake fluid only one side
As per title, bleeding the front brakes on my RHD car and only the RHS bled fluid.
The LHS trickled a tiny bit and stopped.
I proceeded to take off this part as pictured, hoping the block was here but same deal, no fluid pumping through the springy brake hose.
What to check next?
Also is this pipe that sits behind caliper generic? It tore near the hose joint in the process, cant find it on any parts list.
Old Jan 19, 2021 | 06:55 AM
Greg in France's Avatar
What to check next?
The brake pipes are on UK ebay, ans also from Manners, SNG etc. e.g.:
https://www.ebay.co.uk/itm/Jaguar-FR...0AAOSwjDZYhoFs
Also any local brake place can make one up easily.
You may well have a flexible (springy protected one as you mention) that has closed up in the middle, it is good to renew them anyway of more than 10 years old.
The flexible is held to the inner wing by a nut each side on its threaded end. First undo the captive pipe union nut on the inside, then place a spanner on the nuts holding the threaded end both inside and the outside and it comes undone easily. If no fluid comes out of the undone hard line on the inside, then you have a hardline blockage between the junction where the front brakeline from the master cylinder branches to the LHS and the wing join to the flexible.
Old Jan 25, 2021 | 08:43 PM
Dleit53's Avatar
The front calipers can get plugged in behind the bleeder screw. Completely remove the bleed screw and use a small drill bit to clean out the drilled passage behind the bleed screw. The bit should go into the caliper something like 1" to 1 1/2". if you get that clear, I bet fluid will come out. BTW, any talented mechanic should be able to fabricate a brake pipe like yours. I would expect them to cut off the fittings from your pipe and use them on the new one.
Old Jan 25, 2021 | 10:08 PM
Cheers, the blockage was in the flexible hose as once this was removed, fluid came through the hard line inside the engine bay.
Have ordered two flexibles (may as well change both) as well as the pipe which was available locally, luckily.
Old Jan 26, 2021 | 12:52 AM
BBY
You should also as a matter of importance, renew the rear one too. A bit of a pain to get at, but if it too blocks, it will lock on the rears and ruin the diff seals.
Old Feb 16, 2021 | 12:48 AM
Finally got around to fixing this and now have both front wheel actually braking( and quite well too).
BUT, the LH front was not rolling freely when jacked up initially, I hoped this remedy would also fix this.
Took for a 15 minute drive yesterday and pounded the brakes a bit to try loosen it up - it did a little, it is rolling a little better but still resisting. Anything I can do to loosen it further or is this caliper likely seized?
Old Feb 16, 2021 | 01:15 AM
The caliper is rusty or cruded up and the pistons or at least one of them, will not retract properly. It could also be that the pad has jammed in the caliper. This is quite frequent as garages often do not ensure the pads go freely into the caliper. Remove the caliper, take a look, and when fitting new pads to the old, or new caliper, grind down the side edges of the metal part of the pad a touch to ensure it slides easily into the caliper.
If the pistons and bores are not rusty, rebuild kits are cheap enough, but in my view a professionally rebuilt caliper is always a better option. Also if one caliper is bad, the other will not be far behind.
barkergl
Nov 13, 2024 08:18 AM
EdG
Oct 21, 2020 11:43 AM
RGPV6S
Sep 6, 2020 09:49 AM
orangeblossom
Sep 27, 2016 02:10 AM
Vector
Mar 18, 2013 12:41 AM
