Cam Cover Refurbish
Old Dec 21, 2021 | 01:55 PM
Captain Bob 369's Avatar
Default Cam Cover Refurbish
Quick question just replaced my cam cover, new plugs, installed coils with new gaskets hooked up all coil wires have one wire left and can't remember where it came from. Its a single black wire with a terminal end. Looks like it should go on number 6 coil under one of the screws. Didn't want to make a mistake and blow something electronic.
Thanks in advance.
Old Dec 21, 2021 | 03:16 PM
Vee's Avatar
Vee
You may want to send a picture....the camcover has no wire connections. It should just be the six coils.
Old Dec 21, 2021 | 03:31 PM
Default Photo
Had to run to my garage. Right over top on number 6 coil.
Old Dec 21, 2021 | 03:44 PM
petemohr's Avatar
Black wire - Ground (earth).
Maybe the PO's attempt to slow down the deterioration on the magnesium cam cover?
Old Dec 21, 2021 | 03:46 PM
Default Wire
Would it be ok to attach it to the coil screw?
Old Dec 21, 2021 | 06:09 PM
Vee's Avatar
Vee
No! I'll try to figure this out tomorrow, its too dark and cold right now. It is original to the car. It is not an add-on. Judging by the wire size and color, it's a ground point.
Old Dec 21, 2021 | 06:31 PM
Default Thanks
Thanks for the help.
Old Dec 22, 2021 | 10:07 AM
Vee's Avatar
Vee
I can’t seem to find it! I did spit that it is not a long wire. Can you tell me where the other end is connected?
Old Dec 22, 2021 | 10:50 AM
Default Cam Cover
No it’s in a harness. Got another tip. It goes under the number 6 coil touching the cam cover as a ground. It’s running with no leaks so far. Thanks for looking. Picture shows it attached
Old Dec 22, 2021 | 01:38 PM
Vee's Avatar
Vee
So I have a spare harness. I have circled the two ends of that wire. The first too
one is the one you were asking about, the other end is somewhere just before the harness connects to the injectors, which isn’t far.
If you happen to have some time, I suspect if you were to lift the plastic cover over the injectors, you will see the other end.
Im asking because my car obviously doesn’t have this - and I would like to add it.
Thank you!
Old Dec 23, 2021 | 06:37 AM
Default Cam cover
I will get a light and take a good look for the other end. My tipster said make sure it goes under the gasket on the coil, so it’s in contact with the cover.
Old Dec 23, 2021 | 06:45 AM
Keesh's Avatar
I've only seen it on Honda that a cam cover is grounded. I think it is never wrong to ground cam cover. Has little contact with the bottom block because of the gaskets.
....doesnt need to be connected to run the car but doesnt hurt to make it right....
Old Dec 23, 2021 | 07:00 AM
Default Cam covers
Thanks, total agreement
Old Dec 23, 2021 | 07:10 AM
Vee's Avatar
Vee
Thanks. I suspect its connected to one of the bolts that attach the fuel injector tray to the engine. It doesn't go far.
Old Dec 24, 2021 | 04:26 PM
Default Cam Cover
I didn’t pull the harness apart but the other end of the black wire looks like it is attached to the last manifold bolt under the plastic cover for the injectors.
Hope this helps.😊
Old Dec 24, 2021 | 11:07 PM
Vee's Avatar
Vee
It certainly does! Thank you for looking. I will replace that soon.
Captain Bob 369
Dec 14, 2021 09:19 AM
Spud Maat
Nov 29, 2021 03:54 AM
michaelh
Mar 19, 2016 07:40 PM
petemohr
Oct 27, 2013 12:06 PM
EZDriver
Aug 8, 2011 06:18 AM
