Camber measurements, rear
Old Nov 17, 2023 | 03:39 PM
AZDoug's Avatar
Default Camber measurements, rear
I don't have the setting link tools or whatever they are called that are mentioned in the maint manual, but just setting on level ground, I get
LH: -1.25* camber
RH: 0* camber
Spec says -3/4* +/- 1/4*
I wouldn't think that amount of camber variation would have caused the inner tire wear I mentioned on the old tires, but i have no idea when the wear occurred, maybe before some alignment correction, I will have to keep an eye on it once the car is decently operational.
Question: The manual mentions adding or removing shims between the U-joint mount and the disc to adjust camber angle. Where is good place to get said shims if i need them?
Question: Does anybody use that setting tool, or do you just adjust based on setting on level ground? I assume that setting tool just sets a specified ride height correlation between control arms?
Thanks,
Doug
Old Nov 17, 2023 | 06:51 PM
Doug's Avatar
From the factory there are usually 2-3 per side. You can probably just remove/add from one side to the other. Otherwise I'm sure David at Everyday XJ can fix up up with some.
Long and often debated. Sometimes fiercely . I have never used them.... and have never been unhappy with the results nor suffered any tire wear problems.
Old Nov 17, 2023 | 09:34 PM
AZDoug's Avatar
That a good solid answer; given enough time, i may have even come up with that solution.
Thanks!
(the other) Doug
Old Nov 17, 2023 | 09:58 PM
AZDoug's Avatar
I probably need to verify a failing U-joint isn't the cause of the camber/noise issue, before shim swapping.
Doug
Old Nov 18, 2023 | 12:52 AM
Doug's Avatar
Doug
Or lower fulcrum shaft bearings.
Or differential output shafts.
Old Nov 18, 2023 | 11:32 AM
sanchez's Avatar
I did mine on a level floor with wooden wheel stands so that the weight of the car will be on them giving me enough room to crawl under the car. I have 3 shims on one side and 4 on the other to bring it to within specs. The clossest I could get mine was 0 +/- degrees and that works for me. After about 1000 miles of driving at pretty high speed, I am not seeing any abnormal tire wear. U-joints were in good condition.
Old Nov 18, 2023 | 11:49 AM
Greg in France's Avatar
If you can get there, 0.5° negative camber at the rear greatly improves rear end grip.
Old Nov 18, 2023 | 12:47 PM
Doug's Avatar
I ask my alignment guy to set the neg camber (front or rear) to the max allowable in the spec or as close as he can get. Same with positive caster on the front.
Old Nov 18, 2023 | 03:27 PM
sanchez's Avatar
Even at 0 degrees+/- when I look atthe car it does ook like it has a little negative camber. However, I will check it again soon
Old Nov 19, 2023 | 05:57 AM
RGK20m3's Avatar
Each shim is 1/4 degree; if you truly have zero on both sides, remove 2 shims on each side and you will have -0.5.
Old Nov 19, 2023 | 10:41 AM
AZDoug's Avatar
https://www.lanternmark.com/store/fa...as-gauge-13-17
I have used it a lot . Mostly initial setup on projects before going to a regular alignment shop for a four wheel alignment, and also checking for potential problems.
Doug
Old Nov 19, 2023 | 10:59 AM
Post 4 on this thread
https://www.jaguarforums.com/forum/x...t-data-237195/
Shows how I made a very inexpensive camber guage which is extremely accurate. Basically all you need is a length of ally square tube and a cheap digital angle guage from Amazon etc, ebay etc:
https://www.ebay.com/itm/38555310904...BlBMUIigq4j9Yg
Old Nov 20, 2023 | 10:14 AM
Mguar's Avatar
As a Racer I change camber based on track I’ll be racing at and the tires I’ll be using. Bias ply tires call for less camber than Radial tires but radial tires break away with less warning.
Tight corners like Most of Elkhart Lake really don’t benefit from the bias ply, but at long corners like the Carousel and turn 14 the the warning of bias ply allows me to remain on the edge throughout the whole corner. Without that warning. I’m just not as confident to push the radials to their limit and hold it there.
As I age my reactions are a bit slower and it’s easy to appreciate the warning that bias ply offers over Radial. Some of that may simply be from not racing as often and getting less exposure.
JaguarXKR
Jun 25, 2020 09:21 PM
jehart49
Sep 9, 2017 08:33 AM
sogood
Jan 11, 2016 07:47 AM
DaveInVA
Aug 19, 2014 02:10 PM
Thermo
Jun 30, 2009 07:07 PM
