Can you buy drill bits that cut Anti Clockwise (like easi-outs)
Hi Greg
I can always cut the Brake Pipe with a Bread Knife but the Hardest part is going to be removing the Speedo Sensor, which is almost impossible to get a Spanner on
As unlike your Car this is in the Cage
Why remove it from the diff? It only plugs into the left rear corner in the boot. I'd unplug the sensor there and unclip the connections and remove it with the axle.
Cheers!
There are no rear Seats in my Cars, just the Cubby Box if that's what you meant and I have to admit its a very Tempting idea
Bearing in mind that I'm never going to sell this Car, so its certainly worth looking into, as doing anything on the Brakes, sounds like a bit of a 'Nightmare'
Replacing the Brake Pads is not too bad and I have done that before but replacing the Rotors and Calipers, is a totally different story!
Since you had an MGC you will know what I'm talking about here
But my MGB has a 'Neat and Removable Panel' which is held in place by 'Turn Screws' which you undo in order to get to the Batteries which are behind the front seats
And I wouldn't be at all surprised if that same MGB Panel, wouldn't be a Perfect Fit to go in the bottom of the 'Cubby Box'
Maybe I'll trial fit it to see how it would look!
Daim, Jay Jag Jay, Sidescrollin, does anyone have any thoughts on this 'good or bad'
I'm really hoping Jay Jag Jay, is going to beat me to it with the Angle Grinder!
'Greg' 'Grant' Would that idea hypothetically give enough room to Change the Rotors etc?
Can anyone see any problems?
It 'May' not weaken the Structure as the only bit you'll be cutting out would be in the bottom of the 'Cubby Box' and not the Seats as in a Coupe
OB
Even if you make a hole in the right place, which is VERY unlikely, then you have to ruin the pressed woodchip heat shield beneath it, before then seeing the nipple. Also the body is double skinned under the seat of a coupe and I expect it is in the convertible too. There is also a tubular strengthener in the cavity between these skins and you really really do NOT want o cut that in half. Even if you did all this then you will find the nipple will not drill out properly and you have to change the calliper. Then you remove the cage as the hole you have drilled will not any help with that task...
Really, Alex, removing the cage is not that hard, and changing the rotors is an absolute cinch.
I will pm you a list of what to do!
Hi Greg
Cheers!
I done a lot of jobs on my Cars that I could never have done without your help and also 'Grant' but this would be the Big One and is out of my Comfort Zone
If only Jags had thought to provide some access for jobs like this
But I've not given up on getting the Broken rear bleed nipple out, as there's still a few more tricks that I can try
Cheers!
OB, drop the cage.
While its out replace the radius arm bushes, check diff and caliper bolts are tight, or better still remove and loctite them in. You can also check bearings in the fulcrum shafts, etc etc.
Before you doctor around in a dark area, cut openings into the body, possibly reduce the structural integrity of the car and end up having to take the cage out anyway, just do it the right way. It is easy enough. Couple of hours, few curses and it is out.
It is easier than the less complicated Jaguar IRS MK II of the XJ40/X300/X300/X100 which doesn't have radius arms.
Also, don't get carried away with parts then. Do the job you wantvto, check for damages, refit. I'll be doing a full rear cage rebuild when I get to the rear end. It is easy to get carried away. Just replace this bearing. Just replace that bush. Just resp these screws. Just have that wishbone sandblasted...
One of my failings, while it's out I'll just replace X
I started out just replacing the dampers and ended up with a bare metal respray. Rear cage was sandblasted seam welded then powder coated.
Aarcuda
Sep 8, 2019 07:49 PM
kingnero
Jul 6, 2019 01:15 PM
