Center console removal
Old Mar 10, 2019 | 12:52 PM
Fr. Rick's Avatar
Default Center console removal
How do I remove the center counsel from a 1994 XJS convertible 2+2
Old Mar 10, 2019 | 03:27 PM
I've moved your question from General Tech Help to XJS forum. This is the place to post questions about your model.
Old Mar 11, 2019 | 05:08 AM
orangeblossom's Avatar
Hi Fr. Rick
While I've never removed the Center Consul in my 1995 2+2, I've done it in my 1989 V12
And though I cannot say for sure, there may be some similarities which could apply to both Cars
Where at least on my 89 the key to it all was in removing the Ash Trays, where once taken out of their holders revealed some screws underneath them that held some clips in place
Then once these had been undone, the rest of what to do next just seemed to fall in place
Just be very careful that you don't chip the Ski Slope, if you need to try and carefully lift it out
Your 94 may be quite different but the Photo of my 89 might give you a Clue
Old Mar 11, 2019 | 07:10 AM
Greg in France's Avatar
Further to Orangeblosom's post, and if you want to remove the entire console and not just the ski slope, the radio has to come out and the aircon control knobs removed. Then the circular fixings under the knobs unscrewed. Then (from memory) there are three fixings each side that hold the console to the tunnel, each fixing at the bottom edge of the console, rather hidden by the carpet. Undo these and up it comes, checking carefully for any loom wires that may have to be disconnected.
Old Mar 19, 2019 | 01:38 AM
munkizunkl's Avatar
I just removed the ski slope on a 1989 convertible. Here's how.
  • Lift the armrest and remove two small black screws holding the front crosspiece with plastic latch in the centre
  • Pry out and disconnect the window lift and hood (roof) switches
  • Pry out and disconnect the cigar lighter and cruise control switch revealing two 8mm hex head screws
  • Once these two screws are removed the ski slope can be lifted out complete with ashtrays
1 of 19
Nov 15, 2016 09:36 AM
milestogo
Jun 20, 2016 07:33 AM
Muddydog
Exterior
Oct 5, 2014 10:17 PM
brgjag
Sep 6, 2014 09:05 PM
Simprof
Mexico, South America
Oct 14, 2010 07:26 PM
