Chance to buy 95 AJ16 73k off road for 3 years
Old Dec 1, 2022 | 08:51 PM
Inmass's Avatar
Default Chance to buy 95 AJ16 73k off road for 3 years
I have a chance to buy this. It has been off the road for 3 years because of an elderly driver and has been parked in the garage. Once jumped it started right up, engine sounds good and no warning lights. Exhaust is loud and needs fix. Have only been able to move in the driveway and seems OK. Body is very clean but dusty and the interior looks like new. Anything about these that should have me particularly concerned about these having sat? It will cost me around $6,750 if I buy it. Thank you for any advice in advance. I have a day to decide. It is not a Celebration but does have the AJ16. My last XJS was an 89 I owned almost 30 years ago.
Old Dec 2, 2022 | 02:10 AM
Greg in France's Avatar
Go for it, providing you can DIY the maintenance and any fixes needed as they come along, yourself. If you do not enjoy that sort of thing, do not buy.
Old Dec 2, 2022 | 02:53 AM
ptjs1's Avatar
That's a great spec, AJ16 and the later less-troublesome brake system. AJ16s are indestructible. As long as the body is corrosion-free, everything else is fixable.
Buy it!
Good luck
Paul
Old Dec 2, 2022 | 07:08 AM
Vee's Avatar
Vee
Do it.
There isn't much I can think of that this forum cannot help you troubleshoot and fix.
Check the idle. Should be 720rpm warm in park and 580 in gear.
Check the air conditioning. Not a problem to fix if bad, but you should know what you're signing up for.
Check cruise control.
No check engine light after a drive? Then you're home free....well, $6,750.
That's about it. You'll end up changing all the fluids. I'd recommend changing the hoses, especially the ******* hose just under the intake.
I wouldn't pay any mind to any leaks coming from the drivers side engine of the car. There are about three well known leak points that are common and straightforward to fix.
Old Dec 2, 2022 | 07:52 AM
Jagsandmgs's Avatar
Hi- I live in NH. If you don’t buy this car, please tell me about it so I can buy it. I put 200k on my 95 before the paint fell off. It was still running when it slid down a muddy hill in the yard and hit a tree. -John
Old Dec 2, 2022 | 08:51 AM
icsamerica's Avatar
That is one of greatest cars ever made. The engine, brake system, electronics all are super reliable. The smooth ride, responsive transmission and quiet open air driving experience is unmatched by anything you can buy today. Then there's the color combo. Wow! She's a winner.!
Old Dec 2, 2022 | 08:42 PM
Inmass's Avatar
Thank you very much for all who replied
Old Dec 3, 2022 | 06:57 AM
cornishcat's Avatar
Buy It!! Good price too, if it has any service history all the better.
If its been off the road for 3 years (even in dry storage) check the bushes and under side rubber work, and put new tyres on it too and dont forget to flush out the fuel system with fresh fuel and filters.
Good luck it looks like a really good find. Well done
Some Day, Some Day
Jul 28, 2020 01:22 PM
Some Day, Some Day
Apr 9, 2020 09:25 PM
Daim
Jun 21, 2019 01:27 PM
Tonyorlo
XJ40 ( XJ81 )
May 12, 2019 12:04 PM
Big Cat
Jun 14, 2010 09:10 PM
