Changing Rear Shocks/coilovers
Old May 26, 2011 | 11:00 AM
kthrash's Avatar
Default Changing Rear Shocks/coilovers
How hard is it to change out the rear shocks/coilovers? Dealer claims entire rear sub assembly must be removed. True/False?
Old May 26, 2011 | 01:07 PM
sidescrollin's Avatar
the dealer removes stuff to make jobs easier or faster because they have the equipment to, so you may not HAVE to.
that being said i don't actually know. You can definitely get to the bottom of the coilovers but im not sure about the top. I'd roll under the car and just check it out to be sure. Hopefully someone here has done it before and can actually let you know!
Old May 26, 2011 | 06:19 PM
nosox's Avatar
I had mine replaced a few years ago at a reputable performance shop without any drama. In fact, last year he had to place one of the shocks due to a failure and didn't even need to take off the wheel. Same when I had him replace rear springs.
Old May 26, 2011 | 07:29 PM
that pretty much says it all, cage doesn't need to come out. Off course according to jaguar you remove the Windshield to take out the headliner...so go figure
Old May 27, 2011 | 07:22 AM
NO to the cradle.
Did a set 3 days ago.
A 5/8 and 11/16 spanner for teh top bolt and nut on each shocker. They are awkward up insid ethe cradle. The lower pin is 11/16 each end, and 15/16 is needed for the outer pivot nut to release that brace strap.
Dont loose the spacer on the front shocker lower bolt.
Compressing the springs to remove the collets is NOT fun, and BLOODY dangerous if the compressor lets go, but I use the 2 claw each end style, and reasonably safe. The collets are a pain, and fiddly, and the "fear factor" is always there, coz if the clamp slips your finger is gone.
I am always scared when doing them, those smalish springs pack a real punch and take some reasonable muscle to wind them into a compressed state to get those collets out nad especially back in, but I am carefull, and done many over the years, and still have all my fingers.
Took 4 hours start to finish, and being as I have serious arthritis in both wrists not too bad a time in my opinion.
Old May 27, 2011 | 07:42 AM
Forgot something, I do that.
There is a removeable sleeve inside the top shocker bushing. This simply slides out, so be careful not to lose it, as it will be required for the new shocker. It steps down the inner bore of the top bush to suit the bolt that is used.
Old May 31, 2011 | 08:47 AM
kthrash's Avatar
Sweet, new shocks/struts on the way.. was hoping I could do it in my garage..
I may take the struts down to a buddy's garage and use his big air powered spring compressor to swap out the springs.
Old May 15, 2015 | 08:59 AM
Jimmy James 905's Avatar
Update? How did it go? I'm planning the same thing.
Old May 15, 2015 | 09:54 AM
RagJag's Avatar
Fairly easy job except for compressing those springs. As Grant says, remove the bushing in the top of the shock and put it into the new one.
I had one pair put in by a shop because I had a leaking stub axle seal on one side. Upon asking the mechanic if he had saved the bushings he hesitated and said the bolt fitted perfectly. I came home and took the bolts out to look and the bushings weren't there. We found them in his garbage can.
Cheers, RagJag
Old May 16, 2015 | 05:07 AM
butkusandbale's Avatar
Exclamation
I've just performed this task, Grant Francis is Totally Correct !!! Be Careful !
RaceDiagnostics
Sep 7, 2015 07:28 AM
philwarner
Sep 5, 2015 10:05 AM
Busa R
Sep 3, 2015 05:01 PM
King Charles
Sep 3, 2015 12:40 AM
innzane
Sep 2, 2015 10:08 AM
