Cost or difficulty in changing Trans tunnel mount?
Old Jan 17, 2014 | 06:09 AM
jpitma1's Avatar
Default Cost or difficulty in changing Trans tunnel mount?
I need the rear Trans mount on my '94 6.0 changed. What should this cost at a qualified shop? I am a well experienced DIY mechanic; should I tackle this myself? I've read horror stories on this forum...
Old Jan 17, 2014 | 07:05 AM
Doug's Avatar
While not a pleasure cruise by any means I don't see any reason why changing the trans mount isn't fully DIY-able.
You'll need to support the weight of the transmission and take the tension off the spring....a small floor jack does the trick. After that it's a matter of disassembly and reassembly. The exhaust pipes might hamper access ....my memory is a bit foggy on that. If so, they'll have to be disconnected and allowed to drop down.
Here's a pic....
Engine Mounting-Rear-6.0 Litre - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
#5 in the illustration is the key ingrendient, so to speak, but I'd order and replace all the rubber parts just on general principles. Get it all over and done with at once.
Old Jan 17, 2014 | 07:21 AM
AllanG's Avatar
Doug is right it is a straightforward DIY job.
I'm not sure about the V12 but on my 94 6 cylinder, I ordered a rebuild kit which has all the rubber bits. I did not have to drop the exhaust, just support the transmission with a jack.
Old Jan 17, 2014 | 12:24 PM
sidescrollin's Avatar
pretty sure the mounts range from 20-40 dollars.
The spring can mess you up just like a suspension spring can. Do the job properly and it's not a big deal
Old Jan 19, 2014 | 03:34 PM
jpitma1's Avatar
Thanks to all. Great pic, Doug. Allan, you mentioned a rebuild kit. Where did you get yours? I keep seeing the parts available individually but not as a kit.
Old Jan 20, 2014 | 09:59 AM
dsetter's Avatar
On my 95 6.0 I had to pull one side of the exhaust off to allow clearance for the plate #1 in pic to come off. I really did not think it was to hard and used a trolley jack to lower and lift the plate into position. 2 to 3 hours maybe?
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
EZDriver
Sep 8, 2015 09:25 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
