Cruise control/speed control module
Old Feb 15, 2014 | 10:43 AM
DenverDRS's Avatar
Question Cruise control/speed control module
Good morning,
Attempting to replace the speed control module on a '93. Only problem to this point...I can't find the speed control module on a '93. Anyone know where it's hiding...
Thank you.
Old Feb 15, 2014 | 11:46 AM
AllanG's Avatar
On my 94 it's in front of the passenger seat under the carpeted cover.
Old Feb 16, 2014 | 10:05 PM
dsetter's Avatar
Same on my 95, 2 screws under the carpet on the passenger side releases the plate with the speed control, seat control module and seat heater
Old Feb 17, 2014 | 08:09 AM
DenverDRS's Avatar
Default Thank you!
Found it! My thanks to you both.
Old Feb 18, 2014 | 03:30 PM
DenverDRS's Avatar
Default Still malfunctioning...
Found it, replaced it, didn't fit it.
So far I've replaced the console switch and the module. It is difficult to get the system to engage and when it does, it rapidly and steadily accelerates until the switch is turned off rather than locking the speed setting.
Any suggestions on my next diagnostic steps?
Thank you.
Old Feb 19, 2014 | 03:51 AM
malc4d's Avatar
When the speed control on my '92 didn't work l checked the fuse and switch etc. What l found was that that a small plastic washer like part had gone soft and was not holding the link rod. Part 4 here....
Speed Control Actuator-5.3 Litre - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
Old Feb 19, 2014 | 07:58 AM
AllanG's Avatar
Yes definitely do testing before throwing parts at the problem. It can get pricey!!
My suspicion would be a problem with the vacuum pump/solenoid arrangement in the engine bay. Download the electrical guide from the 'sticky' section and test the inputs and outputs.
Old Feb 19, 2014 | 08:00 AM
AllanG's Avatar
Unfortunately the arrangement is different on the AJ6 cars so this would not apply.
Steviedee1st
Nov 28, 2023 06:32 PM
flyrr100
Sep 29, 2015 03:47 PM
XJsc-guy
Sep 25, 2015 11:09 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
BruceG
Sep 15, 2015 05:47 AM
