Dash lights out
Old Mar 5, 2019 | 09:02 PM
Frank P Diaz's Avatar
Angry Dash lights out
Hey guys, I recently had an issue with the radio on my 83 XJS, I replaced the radio but ever since my dash lights when out.... they were working perfectly fine until then. I pulled the cover under the dash and all seems to be in the right order. Are there any dash light related cables behind the radio I am not aware of? This is my first XJS love it but the dark dash is kicking my OCD into high gear. Please help!!!
Old Mar 6, 2019 | 01:21 AM
Greg in France's Avatar
Look at the fuse, it is easy to short it when swapping a radio.
Old Mar 6, 2019 | 05:10 AM
rgp's Avatar
rgp
you haven't inadvertently moved the position of the pointless rheostat switch under the knee bolster
Old Mar 6, 2019 | 04:19 PM
carsnplanes's Avatar
When you say "dash Lights' , do you mean instrument panel lights(speedometer etc) or other dash lights. Aren't the other non instr panel lights fiber optic where one bulb lights all?
Old Mar 6, 2019 | 11:03 PM
It actually worked on mine but no, I did not move it
Old Mar 6, 2019 | 11:04 PM
all the instrument panel and center console all dark
Old Mar 6, 2019 | 11:06 PM
check the fuse, all good with the fuse
Old Mar 8, 2019 | 02:00 AM
orangeblossom's Avatar
Hi Frank
Maybe you forgot to connect an Earth Wire?
Which could be why your Fuse is OK although the lights don't come on
Old Mar 9, 2019 | 04:05 PM
warrjon's Avatar
There are 5 wires 3 RW (Red White) and 2 RU (Red Blue). One of the RU is feed and the other goes to the trip computer. DO you have trip computer lights?
You could bypass the rheostat by connecting the RU directly to RW, this will verify that the rheostat is good/bad.
If you still have no lights use a DMM and verify you have 12V on the feed RU wire.
Old Mar 14, 2019 | 11:24 AM
rgp's Avatar
rgp
Have you got them back?
annamiata
Dec 8, 2019 02:56 PM
charger12
Apr 4, 2012 04:23 PM
robhair
XJ40 ( XJ81 )
Dec 8, 2011 05:27 AM
85_305
Dec 29, 2009 04:37 PM
