Degree of difficulty. Advice needed. 92 V12 XJS
Old Feb 8, 2018 | 03:42 PM
NCJagman's Avatar
Default Degree of difficulty. Advice needed. 92 V12 XJS
I have three jobs I'd like to do on my 92 XJS V12 convertible and would appreciate advice from experienced XJS owner/mechanics as to just how difficult each job is for a reasonably competent but aging wrencher and how much time each one would likely take.
1) Replace all coolant hoses.
2) Replace plugs wires and Marelli distributor.
3) Replace fuel rail hoses and kit as in V12 Performance.
If you could use a 1 to 10 with 10 being an experienced Jaguar mechanic I'd really appreciate it.
Thanks in advance guys.
Old Feb 8, 2018 | 04:42 PM
sidescrollin's Avatar
None of this stuff is very complicated
1. Pretty easy, there are a few fiddly ones but recall the old hoses are trash, so you can simply cut the old hoses with a razor blade and peel them right off.
(2/10): You are just removing hoses and replacing them, but some can be annoying to access
2. Wires are super easy to replace, don't know about the marelli in particular. Do you mean you are replacing the entire distributor or a service like cap and rotor?
(1/10): You are just unplugging wires and plugging new ones back in
3. The fuel rail hoses are a fairly easy job, the biggest pain in the butt is getting old, very hard hoses off the injectors and rail. The kit from V12 performance is kind of a dumb price. You can get the ferrules, seals, and even new pintle caps and filter baskets for less than that buying the supplies from injector-rehab and hose from your local autoparts store.
(3/10): You are just undoing the fuel rail and removing all the old hoses and putting new ones on. Probably the hardest part will be unplugging the electrical connectors on the fuel injectors
I take difficulty to mean "technical prowess" and not necessarily whether its tedious or a pain to do. Replacing all hoses is tedious, cutting off 12 FI hoses and replacing them can also be tedious but none of these things is beyond the average mechanic. People just like to psych themselves out about european cars.
Old Feb 8, 2018 | 04:45 PM
You'll see your injector in the table towards the bottom of the page. Search the part number to nab all the things you want. Like I said, just buy FI hose at a local store and cut it up yourself.
Injector rehab Bosch Denso Pintle Cap
Old Feb 8, 2018 | 08:52 PM
Jagsandmgs's Avatar
A 92 doesn’t use the 12 little hoses. There’s only two hoses tying the two rails together, and one long one in and one long one out. The injectors mount directly to the rail with o-rings.
Old Feb 8, 2018 | 10:17 PM
VancouverXJ6's Avatar
Is refurbishing your own injectors a thing? Is that cap the thing that makes the spray pattern? I'm curious now as my MPGs are dropping like a rock yet my entire ignition system is 'new' end to end except the injectors themselves.
Old Feb 9, 2018 | 02:43 AM
warrjon's Avatar
If your distributor is a genuine Marelli and in good condition I would not replace it, the new ones are no where near the quality of the original. I have one of each.
Old Feb 9, 2018 | 07:16 AM
brinny's Avatar
Good advice . Well put.
Daim's Avatar
The jobs are all easy. Grant and Greg would both say, that it would make sense to lock yourself in thr garage with enough alcohol whennyou are doing the hoses... It isn't complicated, just frustratimg sometimes. Barely seeing where they go but also some hoses are just a tight fit.
The fuel hoses and HT leads are a piece of cake
Old Feb 9, 2018 | 10:14 AM
Doug's Avatar
Well, I dunno about 'refurbishing'....but there's lots of guys who DIY injector cleaning. Check on You Tube
If you want or need more than that, I suggest....
Jaguar Fuel Injector Service
I think the pattern is established by the tiny orifice/outlet/nozzle/whatever at the tip of the injector itself. I'm not entirely sure what function the pintle cap serves.
Old Feb 9, 2018 | 10:29 AM
Daim's Avatar
The cap protects the little needle.
Old Feb 9, 2018 | 01:55 PM
warrjon's Avatar
As has been said 92 could have O ringed injector rail. IIRC the change was in the 92 model year.
- Replace injector O rings as they will most likely be hard.
- DIY clean injectors.
- I would measure the resistance of the ignition leads and replace if any were bad.
- Replace ALL plugs, make sure you gap them correctly.
- Inspect distributor cap and rotor- replace ONLY if needed, genuine Marelli items are far better quality than the aftermarket replacements.
- Replace coolant hoses including the hard to get at heater hose.
- Change all fluids, including trans and diff.
Old Feb 9, 2018 | 05:51 PM
Thanks, I kind of thought this but couldn't actually recall every hearing about the later V12 injectors, so I second guessed it.
And to answer OP, the pintle doesn't really affect spray pattern, but they often break so they are good to replace and they sometimes are removed to give the end of the injector a good clean. Replacing the filter baskets can be worth doing though.
I'm sure you can locate the parts for your injector once you identify which it is. Either way, it means the $100 kit from V12 performance definitely wouldn't be worth your time!
Old Feb 10, 2018 | 01:58 AM
orangeblossom's Avatar
Hi Vancouver XJ6
If your mpg is dropping it could be the Vacuum pipe on you FPR (Fuel Pressure Regulator)
As a loss of Vacuum could increase Fuel Pressure and make your Car run rich and give you less mpg
So Check you are getting Vacuum to the FPR and also check the pressure in the Fuel Rail as maybe it could be a faulty FPR
Old Feb 10, 2018 | 05:48 AM
Daim's Avatar
Originally Posted by orangeblossom
Hi Vancouver XJ6
If your mpg is dropping it could be the Vacuum pipe on you FPR (Fuel Pump Regulator)
FPR = fuel pressre regulator
not that he goes looking for a fuel pump regulator...
Old Feb 10, 2018 | 08:15 AM
Hi Daim
My bad, I meant Fuel Pressure Regulator and so I have done a quick edit
Old Feb 10, 2018 | 08:32 AM
JagCad's Avatar
Change or clean the air filter. Don't ask!!!
Carl
Old Feb 10, 2018 | 05:03 PM
Hi NC Jagman
There are some who say that changing the Spark Plugs on an XJS is a 'right of passage' for any aspiring owner
Where having done this job myself I would have to agree, although for someone like myself with almost no mechanical experience
It could be compared to 'Building a Ship in a Bottle' where everything seems to be in the way of what you're doing
And above all this is not the kind of job you want to rush, as one mistake like a Cross threaded plug, could completely ruin your engine
Easy to do and just one of the reasons that I'll never take my Car to a 'Shop' to be fixed
Where for just Changing the Spark Plugs it could Cost $500
As while changing the Spark Plugs on most normal Cars could be done in well under Two hours
Changing the Plugs on an XJS could well be measured in days
Where since this was the first time that I'd ever done this job, changing the Spark Plugs took me nearly Three days!
One of the worst parts of doing this job getting to the Spark Plugs underneath the Air Con Motor,
Which was a real 'Bar Steward' to lift out and an even bigger 'Bar Steward' to put back because its such tight precision fit
And when I finally got to them, they were in so tight. that they were a 'Nightmare' to get out
So it would be a good idea to spray them all with Penetrating Oil, just like I did
Which kind of had me wondering if those two plugs had ever been changed during the life of the Car
But when you put the New Spark Plugs back, they only need to be finger tight, plus about 5 degrees
As you need to be Careful, that you don't strip the Threads by over tightening
If you are taking the Fuel Rail off, then this will make the job a whole lot easier but take Photographs of everything you do
And also label every lead or wire that you take off, as its so easy to get lost when they have to go back
Based on the Fact it took Three days for me to do this job, in terms of difficulty I would have to rate it as 7/10
Though if I have to do this again on one of my other XJS's then I would think I could do the job in just a couple of days
For as I may have said before, this is not the kind of job that you want to rush
The best results can be achieved if you take your time
You can see how I did mine on Page: 8 of my 'Cherry Blossom' Restoration Thread
And here is the Link straight to it: https://www.jaguarforums.com/forum/x...-122634/page8/
Old Feb 11, 2018 | 01:14 AM
Hi Vancouver XJ6
I hate to piggyback on OP's thread but maybe its all relevant anyhow - does the size of new Vac lines actually matter in these cars or can you just order 10ft of [standard size silicone hose] so long as the thing fits over the nipple(s) I'd imagine on any 'new to me' car it would be nice to delete the vac line maze and just have the minimum necessary ones in new hoses.
Edit: My car would seem to have different sizes connected to other size hoses like evidence of some shoddy DIY work with several plastic smaller to bigger connection pieces here and there
Old Feb 11, 2018 | 02:16 AM
Greg in France's Avatar
It does not matter. Standard 4mm silicone vac tube is a great idea. Also worth replacing that to the gearbox modulator, and the rubber elbow on the modulator spigot. When I did mine (the old one was not porous) the responsiveness of the gearbox was transformed.
Old Feb 11, 2018 | 03:15 AM
Very interesting, it's been lazy going from D to 2 where as last summer the shift was so hard (proper imo) I was afraid of gearing down manually.
Is the gearbox one easy to find or is this one of those things where we have to zoom in on 1980s diagrams to find the line?
