''Duckbill'' location/access
Old Sep 1, 2019 | 08:17 PM
anyoldiron's Avatar
Banned
Default ''Duckbill'' location/access
Hello.
l have a wet passenger footwell in my 1982 XJS (FHC no sunroof) research tells me a good place to start is check and clean the duckbill..................but im not exactly sure where it is. ls it under the wiper scuttle? What do i have to take off to get to it.
Old Sep 1, 2019 | 09:10 PM
Doug's Avatar
The air intake plenum at the base of the windshield is drained by two tubes running from the firewall forward. Often clogged with leaves and debris
The plenum of the evaporator case, inside the cabin, is drained by two small tubes that run from the bottom of the evaporator case thru the floor board, just aft of where the engine and transmission come together. Easy to see if the car is elevated; gently clean with a stiff wire; be ready for a flood.
Either or both can account for wet floorboards (and, sometimes, wet feet!)
Old Sep 1, 2019 | 09:14 PM
Doug's Avatar
Post #14 here......
https://www.jaguarforums.com/forum/x...e-cabin-49204/
.....shows a picture of one of the plenum drain tubes that run forward from the firewall
Old Sep 2, 2019 | 03:55 AM
Bez74's Avatar
Hello Mark
The duckbill area.
After looking at these drains - I have come up with the following thoughts
If the plenum drains are clear - they drain straight over the front suspension, which is not good for the suspension over time
If the plenum drains are clogged - they drain down the left or right near your (or your passengers feet)
If the plenum drains are clogged - they eventually rust a hole in this duckbill area, and you get wet feet.even faster
If the plenum drains are incomplete - they drain just near the brake booster of windscreen wiper bottle, gets in underneath the heat insulation that is there and rusts a bit of the steel work
Just one of those features
Steve
Old Sep 2, 2019 | 07:44 AM
anyoldiron's Avatar
Banned
Thanks Gents, i will get that done today.
Old Sep 2, 2019 | 02:48 PM
VancouverXJ6's Avatar
I coated the interior of my car's wiper motor area with a marine grade rust converter/sealer, as per typical Jaguar design you'll notice the actual drain holes are slightly higher than the lowest point in the cavity...you'd think being in the UK they'd of prioritized drainage.
Not going to bother doing bondo plastic surgery just dump the sealer in till it flows out the drains worked so far
Anglicomarine0326
Jun 3, 2017 11:10 PM
AquaticEngineer
Nov 30, 2013 10:08 AM
M90power
Sep 23, 2012 12:34 PM
Boomer from Boston
Jul 27, 2011 07:17 AM
dvnice
Oct 20, 2008 04:53 PM
