Electric Aux Fan and Temp sensor/switch questions
Old May 12, 2014 | 10:36 AM
ptjs1's Avatar
Allan,
Tks for the info posted on the other thread re the temp range. Just to further confuse things, Greg's AJ16 may have the switch down the bottom, but my AJ16 has it at the top part.
The wiring fix to run the fan all the time with the aircon is common practice here in the UK.
Paul
Old May 22, 2017 | 02:16 PM
RickE's Avatar
Red face
Thanks to everyone who posted on this very old thread. I've encountered the problem on my 1996 AJ16 and thought something was wrong (overheating due to needle between N and H), but this old thread has put my mind at ease. I thought my aux fan switch was defective, but is actually working as designed.
Old Sep 6, 2017 | 01:22 AM
muzz's Avatar
Hi all, so can anyone tell me how to run the aux fan while the a/c is running, it's a good idea in Australia.Thanks all.
Old Sep 6, 2017 | 02:27 AM
Greg in France's Avatar
Great XJS Prophet of the South, the Wizard of Oz, AKA Grant Francis will surely see this and post.
Greg
Old Sep 6, 2017 | 02:57 AM
Murray,
Greg threw a rock or 2 on the roof and got me out from under one of the Jags.
What Jag are you wanting to alter, your profile states an XJ40, and they are quite different from the XJS as far as wiring and modules etc are concerned.
Old Sep 6, 2017 | 05:01 AM
warrjon's Avatar
If you use a relay to switch the eFan then activate the relay via the AC compressor clutch power supply this will work on any vehicle.
Old Sep 6, 2017 | 06:02 AM
Warren,
My thoughts exactly, but there is a dim bell (yeh I know) in my head from the daughters XJ40, and when we fitted thermo fans to it, and the wiring was odd, as was the car, but it was not simple, I think??????
I will ask her, she will remember.
Old Sep 8, 2017 | 02:00 AM
  #28
muzz's Avatar
Thanks, so if I run the trigger wire from the a/c to the trigger wire of the fan, it will work?
On the flip side, if the fan turns on from being to hot, the a/c will turn on because the trigger is connected from the fan to a/c. True?
Old Sep 8, 2017 | 02:22 AM
ptjs1's Avatar
Muzz,
Not if you do as Warren has mentioned above and run the A/c feed to a relay and thence run the aux fan.
Paul
Old Sep 8, 2017 | 02:44 AM
  #30
warrjon's Avatar
DO NOT DO THIS, the AC compressor is switched by the AC ECM and you will damage the ECM if you do this.
Use the wire that switches the AC compressor on to also switch a relay on, this wire will go to pin 85 and pin 86 to ground.
Then wire to the + terminal on the firewall with a fuse (mine uses a 30amp as the 20amp would blow when the fan switched) to pin 87.
Then pin 30 goes to the fan.
NOTE: A 40amp horn relay will do the job. Be aware some relays have a protection diode on pin 85 or pin 86 if you get one of these post the specs as these are polarity sensitive for the switching coil.
Old Sep 9, 2017 | 01:43 AM
  #31
muzz's Avatar
Thanks all, I run the a/c clutch power, as a trigger , to the aux fan relay trigger and as soon as the compressor cuts in , the fan is on. fan bloody tastic!!! punt.
Old Sep 9, 2017 | 01:44 AM
  #32
muzz's Avatar
I am now replacing the I R remote receiver.
Old Apr 9, 2025 | 09:47 AM
  #33
monkfe's Avatar
Originally Posted by XJSFan
There are Thermo switches that will turn the electric fan on at a cooler temperatures. I removed my original 85C temp switch and replaced with a 82C switch. Just do a google search and you will find all the info that you need...
Do you happen to have the part number for this switch? with the lower temp threshold?
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
1100me
Sep 7, 2015 06:26 AM
Bcrary3
Sep 3, 2015 03:48 PM
