EMERGENCY: Oil pan ruptured
Old Sep 4, 2015 | 11:20 AM
Dymaxxion's Avatar
Default EMERGENCY: Oil pan ruptured
So I just moved back to Detroit for school, and not 10 minutes after getting to the city I hit a massive pot Hole, I made it to my parking structure, but 5 feet from my space my engine shut off. My oil light came on and apparently I'd been leaking all over Detroit. 90% sure it's the pan. What is replacing it going to entail? Do I have to pull the engine? Car starts and runs fine when oil is added, buy it leaks out fast. If I have to take it to a shop any idea what it will cost?
Old Sep 4, 2015 | 01:09 PM
ptjs1's Avatar
Dymaxxion,
You haven't said what type of engine you have.
Paul
Old Sep 4, 2015 | 01:24 PM
Dymaxxion's Avatar
Originally Posted by ptjs1
Dymaxxion,
Paul
Sorry, it's the 5.3L V12
Old Sep 4, 2015 | 01:43 PM
xjsman89's Avatar
Brendan, it's Collins here. I should have known you were on the forums too. Sorry to hear about your pan woes, hopefully it's a quick solution.
When I was down there changing the oil it didn't look too complicated, but I have obviously never done it myself. I'm sure someone will be able to lend you some insight. It's a pity you aren't closer or I would be happy to help out.
Old Sep 4, 2015 | 02:15 PM
Dymaxxion's Avatar
Got the belly pan and spoiler off to get a better look. It now appears that the leak is above the pan, to the front drivers side of the engine. When the car is off and I pour oil in it just rapidly drips out. I can't get my head any further under and my jack seems to have given out. Any idea what I could be dealing with? Thanks.
Old Sep 4, 2015 | 02:40 PM
Brake buster's Avatar
that will be your engine oil cooler pipe union , either the flow or return
BB
kthrash
Feb 25, 2019 10:20 AM
JCam
Oct 23, 2016 08:27 PM
Davidvdm
Oct 7, 2015 03:18 PM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
