engine freeze plug?
Old Feb 27, 2012 | 03:26 PM
sidescrollin's Avatar
Default engine freeze plug?
I was wondering what the actual name was for the rubber plugs in the engine, there is one just under the head that i noticed is weeping some and i wanna replace it...but i cant figure what its called!!
it looks like a rubber freeze plug but i cant find it
Old Feb 27, 2012 | 04:42 PM
warrjon's Avatar
You need to be a little more specific. Is this a V12 or I6?
If V12 are refering to the half round rubber seals at the back of the head behind the camshaft?
Old Feb 28, 2012 | 05:17 PM
5.3 v12
no it is a round seal at the front of the block just under the head.
Old Feb 29, 2012 | 01:09 AM
Greg in France's Avatar
Originally Posted by sidescrollin
5.3 v12
If this refers to the rubber bung just above the curved casting which is part of the water pump, it is an access hole to release the timing chain tensioner, should it ever be necessary. Part number C 37925 Plug (chain adjusting).
New bungs are available, though getting the old one out needs care as they go hard and bits drop into the sump - though not dangerous if they do. A guy called Ron Kelnhofer makes lovely aluminium ones with a positive locking system. Much better and no leaks.
Greg
D.K
Dec 10, 2023 02:05 AM
Gus
Oct 15, 2019 12:29 PM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 2, 2015 12:48 PM
XJsc-guy
Sep 2, 2015 11:43 AM
