evertime i do something to benefit something happens
Old Mar 27, 2012 | 02:26 PM
Qgregg's Avatar
Default evertime i do something to benefit something happens
Had oil changed yesterday, top of the line new oil filter, new air filter.
now when i crank the car the oil pressure shoots strait to the halfway mark.
maybe this is normal i dont know. before the change it sat at the bottom and rose as i drove the car.
Old Mar 27, 2012 | 02:35 PM
Sarc's Avatar
@Qgregg
Are you getting the oil pressure at half way when you are cranking ? (or after it's started?)
I've had my oil changed a few times and it's never done anything to change the behaviour of the oil pressure gauge..... Mine will go to about half way once the car is started from cold. When driving (still cold) it goes to 3/4. Once it's warmed up it sits around half way when driving, and can come all the way down to almost 0 when hot idling (but the idiot light never comes on)
This correlates nicely with my oil temperature (I have an aftermarket gauge with the sender braised into the sump), ie when the oil is cold the pressure is high, when it's hot the pressure is lower.
Old Mar 27, 2012 | 02:46 PM
Qgregg's Avatar
cold cranking going strait to middle, after i drive a little it drops to zero then increases as i accellerate.
Old Mar 27, 2012 | 02:52 PM
Sarc's Avatar
I've never watched my oil pressure gauge while I'm cranking (and the car is currently in the shop with the transmission out so I can't check). Maybe others can chime in if they have cars that are actually running and they can go check.
My first thought would be that I wouldn't trust any gauges while cranking the starter as the voltage could be fluctuating quite a bit, but maybe thats wrong.
Old Mar 27, 2012 | 03:04 PM
Qgregg's Avatar
yea it seems like before the oil change it stayed low and as i speed up it increased, if it went half way i was haulin ***, but like i say now it jumps on up to half way and thats idling @ 1000 rpm's(a little high i know) in park.
Old Mar 27, 2012 | 03:19 PM
M90power's Avatar
quite screwing with that whack *** electrical gauge and get a proper mechanical gauge and some copper tubing.
Old Mar 27, 2012 | 04:24 PM
Qgregg's Avatar
I hear ya, sounds like a good idea. Kiils me when i cant fix something...
Old Mar 27, 2012 | 04:38 PM
Mikey's Avatar
I'd find out the actual oil pressure before going any further. Oil level in the sump OK?
H20boy
Dec 24, 2024 03:23 PM
Stoney85
Jun 10, 2021 09:14 PM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
Daim
Nov 28, 2016 09:28 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
