Facelift Steering Wheel Replacement
Old Nov 21, 2019 | 02:48 PM
Josh Knight's Avatar
Default Facelift Steering Wheel Replacement
Hi everyone,
I have purchased a celebration model US spec wood steering wheel for my 94 XJS. Before I dive in and try to do this myself, is there anyone here who has experience removing the airbag and steering wheel who could help me through the process?
Old Nov 21, 2019 | 10:16 PM
Vee's Avatar
Vee
1. Disable the firing pin with the special D shaped tool. Have you made one of those.
2. Once disabled, you should be able to access the bolts that hold the wheel to the column. I recall an un-disabled firing pin blocking access to one of the bolts, so being extra careful won't help. The firing pin screw needs to be fully turned in. I think that allows some small hinged door to open. It's very straightforward.
Old Nov 25, 2019 | 07:03 PM
Default Changing Steering Wheel /with pics
Remove the bolts from these two holes with 13mm socket. Turn wheel 90 degrees each way to access.
Second bolt hole
Turn wheel upside down, pry open this flap with a flat head screwdriver
Use JD159 (impossible to find) screwdriver bit or hammer a small socket to make shift socket into the “D” tool that fits around this “D” shaped screw and turn counter clockwise 12 times (until stops)
Slide this metal bracket over to access third bolt, turn “D” (arming pin) clockwise a few turns while holding bracket open and arming pin will hold open bracket for you
Exposed third bolt, undo with 13mm socket. Once loosened, remove airbag. Once removed smoke cigarette and pat yourself on the back.
Use large socket to loosen and remove steering wheel
Slides off fairly easily, wheel puller not required
Use a thin flat head screwdriver to remove old horn buttons to put in new steering wheel
It’s a single piece, no wires
Your new beautiful wood steering wheel, as the XJS always should have had.
Old Jul 11, 2020 | 11:07 PM
fishbait1's Avatar
once the 2 bolts have been removed will the airbag lift out so you can get to the pin and third bolt?
Old Jul 11, 2020 | 11:40 PM
once you have removed the 2 bolts, then you have to turn steering wheel upside down, open third flap, which reveals arming pin. use JD159 jaguar tool (or homemade mashed socket) to disarm airbag by turning 12 times. This allows access to sliding mechanism, which reveals the third bolt required to remove airbag.
like disarming a bomb except more complex
Old Jun 9, 2021 | 10:54 AM
mikebaker3's Avatar
Josh;
Was there a part number associated with the wood wheel that you purchased?
Old Jun 10, 2021 | 06:44 AM
ptjs1's Avatar
Mike,
the part number for a US Wood & Leather airbag wheel is HHF9181AALEG
Paul
Old Jun 10, 2021 | 09:47 PM
Originally Posted by mikebaker3
Josh;
I believe that’s the part number there in Paul’s post. Hard part to find though, they were only available on a select group of celebration models. I found mine through Coventry West, and frankly I was lucky. I searched for months.
petemohr
Oct 3, 2018 09:13 AM
King Charles
Jul 14, 2017 06:53 AM
orangeblossom
Dec 23, 2016 03:07 AM
95Leaper
Sep 9, 2016 01:02 AM
bodger
Jun 22, 2015 05:10 PM
