Factory radio
Old Aug 23, 2020 | 09:45 PM
Rchuda's Avatar
Default Factory radio
I have a 1994 Jaguar XJS convertible. I load trunk CD exchanger with CDs. When I press Tape CD button it does not play CD. Is it just defective button on radio? Any other troubleshooting thoughts ?
Old Aug 24, 2020 | 05:00 AM
stuizzy's Avatar
you should get a message on the display to say which CD it is trying to play. Something like “disk 1” etc.
i have found that moisture in the CD player can cause problem, blowing warm air in using a hair dryer cured it for me
Old Aug 24, 2020 | 07:43 AM
malc4d's Avatar
Have you checked the cable behind the CD unit.
Old Aug 24, 2020 | 09:19 AM
Rchuda's Avatar
Default CD changer
There is power to CD changer in trunk since I can insert CD cartridge. The car is new to me. Should a cassette tape automatically play or do I still need to hit the CD Tape button? That would allow me to troubleshoot if button is defective. I did have to slide the radio out to get the serial number but i was really careful. Not sure if cable may have come loose then. But I still have power at CD unit.
Old Aug 24, 2020 | 10:02 AM
stuizzy's Avatar
After inserting the CD cartridge you need to press the CD button. The unit should then try and load the first CD. If it cannot load or play it you will get a No disk message on the head unit. It will then try an load CD 2 etc.
If you open the trunk you will hear it loading the CD's. .
You can load a specific CD by pressing 1,2,3 etc.
Old Aug 24, 2020 | 11:26 AM
Rchuda's Avatar
press CD button on head unit? or is there one somewhere else?
Old Aug 24, 2020 | 11:31 AM
stuizzy's Avatar
The Tape/CD button, bottom right of the head unit in the dashboard
Old Aug 24, 2020 | 11:41 AM
Rchuda's Avatar
I have power to changer in trunk because the green light comes on to eject cartridge. Once I load CD's and press TAPE CD button there is no change. Not sure if problem is in the radio.
Old Aug 25, 2020 | 02:39 AM
AndreasXJS's Avatar
Suggest to post a picture of the radio.
Old Nov 29, 2020 | 10:03 PM
afterburner1's Avatar
Don't think the problem is the radio. Take the black cover off your player . Look at the input cable and check the eight wires and ground leading up to the input pin. These wires are very thin and you might have one broken. Also clean the lens on your laser while you are there. Youtube has good info on player repairs.
On the radio screen you should get cd info such as disk 1, 2, 3 etc, No disk. No disk repeated indicates a dirty laser lens
jeremys
Mar 18, 2018 12:10 PM
steven300
Nov 3, 2013 12:57 PM
Censport
Sep 6, 2012 10:22 AM
tgds932001
Jun 30, 2010 12:55 AM
kandA
May 1, 2009 08:56 AM
