Are factory wheels porous?
Old Nov 27, 2025 | 04:36 PM
AZDoug's Avatar
Default Are factory wheels porous?
'88 XJS for reference.
The tires that came with my car, they dropped pressure fairly rapidly, they were old, so i didn't keep them long.
Replacced with new Cooper V rated tires, same thing, tire pressure drops much faster than on any other car I own, even with the same basic Cooper tire, or Michelins, or Goodyear, etc.
Valve stems are new, no leaking from the valve cores, but pressure degrades 2-3 times as fast as any of my other cars.
Doug
Old Nov 28, 2025 | 01:47 AM
Keesh's Avatar
Have you checked the rim flange to see if they're leaking? First, thoroughly check the rim flange for damage(corrosion or oxidation) or dirt before mounting the tire.
Old Nov 28, 2025 | 01:29 PM
Jagboi64's Avatar
Generally not, but it's also worth checking for cracks. I had an X Type rim crack after hitting a pothole and it wouldn't hold air.
Old Nov 28, 2025 | 02:36 PM
Doug's Avatar
I've had this occur only with the "Lattice" style XJS wheels, FWIW. They leak down a bit faster than others.
Old Nov 28, 2025 | 07:48 PM
89 Jacobra's Avatar
Active Streak: 30 Days
Any Aluminum / Alloy wheel can be porous. Highly unlikely in this day and age, with the newer manufacturing technology. We used to pull the tire, clean the rim and scuff it with sand paper, and then paint the inner area, (not the bead) with Rustoleum. Which cured the problem. This was also a common trick for older Harleys which suffered from porous engine cases causing them to leak as the oil seeped through the aluminum itself.
Jack
Old Nov 28, 2025 | 10:17 PM
AZDoug's Avatar
Well, the wheels were made almost 40 years ago, and older Brit cars have a reputation for leaking oil, so I wouldn't put leaking air out of the possibility.
Good tip on the Rustoleum as a sealant
Doug
Old Nov 30, 2025 | 06:53 PM
89 Jacobra's Avatar
I was 13 years old in 1971 and my Dad had bought a Basket Case 65" XLCH Sportster. In the process of rebuilding the engine, I saw him paint the inside of engine cases with "Red Rustoleum". Being the curious newbie, I asked why and he told me. I can attest that his Sportster didn't leak a drop when it was done. Problem solved as Most Harley's in that day and age needed a diaper. Lol.
Jack
Old Nov 30, 2025 | 08:31 PM
Mac Allan's Avatar
That's the Factory Authorized Rust Thwarting System (FARTS)!
Old Dec 1, 2025 | 09:51 AM
Edelweiss's Avatar
I was always told British cars leaked oil because it helped maintain the gravel driveways in front of the manor homes...
pwakeling
Jun 26, 2021 08:47 AM
Spikepaga
Sep 25, 2019 01:07 AM
rlembach
Aug 25, 2015 12:45 PM
Kevin93940
Mar 26, 2009 02:43 PM
vitaman
Aug 22, 2008 12:26 PM
