Fan shroud mounting question
Old May 16, 2016 | 11:43 AM
Doug's Avatar
Default Fan shroud mounting question
Hi !
Take a peek at this illustration and note the mounting tabs at the top of the shroud.....
Cooling Fan Cowl-Mechanical-5.3 Litre - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
Here's my question:
Should there be rubber cushions at those mounting points? The illustration doesn't show any, and frankly I don't recall removing any. But I have a nagging thought that those holes should have those round grommet-like cushions as used in various other locations.
Thanks for any help
Old May 16, 2016 | 12:46 PM
Daim's Avatar
Hi Doug,
As I removed mine, there were no rubber mounts or rings or so for them...
So I'd say you ought to let go
Old May 16, 2016 | 01:26 PM
orangeblossom's Avatar
Originally Posted by Doug
Hi !
Here's my question:
Thanks for any help
Hi Doug
No rubber mountings on mine and the Shroud has never been out.
Old May 17, 2016 | 12:18 AM
Both of mine were rubberless waaaaaay back before Efans.
I know those rubber units you remember well. They are not used here.
Old May 17, 2016 | 12:56 AM
Greg in France's Avatar
On my 1985 the shroud fixing holes had rubber cotton reels OEM. The holes on the shroud fixing brackets were quite large, and without the rubber and a washer on top before the fixing nut, the shroud would have fallen off. Maybe it was changed at some point?
if you have an main electric fan in place of the engine driven one, attached to the shroud, some sort of damping is quite useful to prevent vibrations into the body.
Greg
Old May 17, 2016 | 07:34 AM
Doug's Avatar
Yeah, the large holes are just begging for the 'cotton reel' mounts! That's why I had to ask !
But.....
The large holes, left rubberless, give you quite a bit of adjustability when positioning the shroud
I'm using all original stuff. The 3 legged e-fan mounting has the rubber cushions on each foot, as you know, I'm sure.
I'm going with 'rubberless' mounting on the shrouds themselves
Cheers and thanks
Old May 17, 2016 | 09:00 AM
Nothing a bit of bending on those thin gauge shroud brackets will not fix, Doug! The legendary NVH experts of Jaguar's illustrious past will be turning in their graves...
Greg
Old May 17, 2016 | 08:11 PM
Doug's Avatar
Greg
Maybe just a grumble or two.
The e-fan assembly is mounted to the 3-leg bracket using the rubber cushions, and the bracket-to-shroud mounting uses the rubber cushions as well.
BobRoy
49
Sep 18, 2016 10:48 AM
xjsman89
Aug 26, 2016 05:12 PM
kenatofc
Apr 3, 2016 10:42 AM
Uncle Fishbits
Mar 30, 2016 05:16 PM
Uncle Fishbits
Mar 24, 2016 06:20 PM
