So today fix was. I had broken a fiber optic cable for ac face plate. I cut the broken end flush put it in a lathe drilled it out with a .086 bit slid the cable back in kinda of a tight fit which is good and I now have a working fiber optic cable hope this helps someone.
yes mine was close to the end so no biggie but I bet you could bore out a tube to make a coupler if you already had not done led good fix on your part too
I removed the AC control panel, dismantled it and drilled holes behind the icons so the light can shine through. The LED strip is self adhesive and is stuck behind the panel not to it.
They are wired to the dash light so they dim as well.
I have a bunch of broken fible-optic cables. Some we broken before, some broke when I was fixing gearshift linkage...
I was looking forward to somehow restore the whole fibre-optic setup, it was a surprise to find it and figure out what it is the first time I saw it. I was thinking to use fibre optic cables from one of those decorative nightstand 'bushes'.
if there are tiny LEDs that would fit onto holes where cables go - that would be my second choice.
My f/o was really dim. I removed the old crappy bulb and fitted a led with a reflector to produce more focused light. I had to trim the housing a bit to fit the led. Worked great
If you're looking to retain the optical fiber system but upgrade or replace the light source I found there are many flashlights that provide nice reflector/led assembly. Combined with a 6v transformer provide a very bright source that's almost perfect for the FO cables.
Warrjon
My fibre optics produce a pathetic glow, have you got some pics or a writeup of precisely what you did, please?
Greg
Hi Greg,
While I have the console out I took pics of my LED mod behind the AC control panel. The strip LED's in the last pic are wired into the dash lights, there is another strip LED on the other side as well
