First real road test! Didn't go to plan!
Old Jul 4, 2019 | 09:22 PM
Some Day, Some Day's Avatar
Slightly off-topic, sorry, but since you've got the cluster out, can you confirm if that is actually wood, or just imitation grain? I suspect the latter quite strongly.
Old Jul 4, 2019 | 11:11 PM
Jagboi64's Avatar
Originally Posted by Timeisrelative
I then realized there is a single wire sensor behind the first sensor. Is that the one that the gauge reads from?
Yes. The other sensor is for the fuelling control.
Old Jul 4, 2019 | 11:14 PM
Jagboi64's Avatar
It's imitation. Same with the X300 saloons. All the other wood in the cars is genuine.
Old Jul 5, 2019 | 01:00 AM
Timeisrelative's Avatar
Yeah definitely fake wood coating on plastic. Of course one of the things I’m seeing is that it could be a grounding issue, which can possibly be remedied with cleaning of the contacts on the printed circuit, and a ground wire! Of course I didn’t see that until after I put everything back together! Smh!
Old Jul 5, 2019 | 02:40 AM
Huh. Fake wood. Suspected as much. Bit cheap of them, frankly. Thanks, anyway.
Old Jul 5, 2019 | 01:46 PM
Yeah and mines actually getting small "dots" on it if you look closely at it. I decided to tear the cluster out again and cleaned up my contacts and went ahead and added a ground and…temp gauge still doesn’t work! Also it’s decided to rain off and on. Drrrrrrrrrrrr
Old Jul 9, 2019 | 05:43 PM
Welp I bought a IR thermometer and after a 4 mile drive it’s reading right about 190f on the upper radiator hose and thermostat housing, so I think its ok. Unfortunately now my oil gauge is pegging to the right. Smh! I know they are on the same ground so I am wondering if it’s still a ground issue.
TheBaltimoron
Sep 30, 2017 01:39 AM
TreVoRTasmin
Mar 22, 2017 06:30 PM
sikest
Jul 23, 2016 09:04 PM
Torrid
Sep 14, 2014 08:06 PM
McJaguar
Dec 19, 2008 11:28 AM
