Flasher relay 1995 4.0 Cab
Old Nov 23, 2024 | 06:44 AM
Jag06530's Avatar
Default Flasher relay 1995 4.0 Cab
Hi, we have no indicators or hazards and I believe the relay flasher is missing as shown in photo below, situ LHS drivers side the yellow relay holder
Can anybody confirm the part number for the relay, i believe it is a 4 pin, thanks and any pictures welcome to confirm correct location
Old Nov 23, 2024 | 07:14 AM
ptjs1's Avatar
Jag06530,
It does seem as if the flasher unit is missing.
I'm assuming you don't have the workshop manual etc? See here for the the electrical wiring diagrams for your car and you'll see the relay layout:
94 XJS 4.0L Electrical.pdf
Also see here for Jaguar's parts website and the part number for the flasher unit:
Genuine Relay And Fusebox-driver's Side For Jaguar Xjs Sports Coupe/convertible 1975 - 1996 Classic | Jaguar Land Rover Classic Parts
Good luck
Paul
PS You have a 4.0 Convertible, not a Cabriolet. A Cabriolet is quite a different model.
Old Nov 23, 2024 | 07:29 AM
Jag06530's Avatar
Thanks for links and the part DAC6081 which is discontinued, can anybody know or show a flasher relay that can be substituted for DAC6081 ?
Quinton Hazell XFL115 Indicator relay 12v Electric 92A anybody using ?
Old Nov 23, 2024 | 09:25 AM
ptjs1's Avatar
If you just google Jaguar DAC6081, you'll see that the QHXFL115 seems to be identified as the equivalent
Paul
Old Nov 24, 2024 | 08:21 AM
uspurs's Avatar
Fwiw, when I put LEDs for the turn signals in my '94, I used this:
Vensans Flasher Relay, CF14 JL-02 3-Pin LED Flasher Flash Relay for Turn Signal Light Hyper Flash Fix 12V_PQ https://a.co/d/c3NDOsR
It is a 3 pin and I believe should work for regular bulbs.
Old Nov 24, 2024 | 11:18 AM
Jag06530's Avatar
Thanks, a few alternatives found to the DAC relay
Next thread will drivers seat and mirrors to get working, need to check memory seat fuse first
Old Nov 24, 2024 | 11:59 AM
uspurs's Avatar
I had a problem with driver's seat (wouldn't move forward / backwards, seat back also stuck in a rather uncomfortable position) when I bought mine - turned out the module under the seat was damaged (water ingress) and had to be replaced; used unit from eBay.
Old Feb 16, 2025 | 04:11 PM
Jag06530's Avatar
We come back to the flasher relay that we still need to source. We have 4 wires into the relay block as per first photo. It needs a 4 pin relay as we have tried the 3 pin and still no indicators or hazards (fuses blow)
Can anybody confirm the flasher relay used in a 95 Convertible ?
4 pin is a DAC 1731
Old Feb 23, 2025 | 07:12 PM
Scottsxjs95's Avatar
This is what is in my 95 XJS , I know it’s a little late but might help
Old Feb 24, 2025 | 02:15 AM
Jag06530's Avatar
Thanks, do you have 4 wires going to the relay flasher block (yellow) , that relay is only 3 pin correct ?
Old Feb 25, 2025 | 11:20 AM
Yes four wires going in, three prong flasher.
Jrizzo003
Sep 20, 2024 04:59 AM
Bowmanconsult
Jan 8, 2024 02:23 AM
Charlroi19
Jun 19, 2022 08:27 AM
69jaguar
E type ( XK-E )
Nov 23, 2021 09:11 AM
rgp
Jun 27, 2019 05:29 AM
