Fosseway Remote Bleeder Question
Old Aug 12, 2020 | 03:42 PM
orangeblossom's Avatar
Default Fosseway Remote Bleeder Question
Hi Guys
Does anyone have a Photo/s (or installation instructions) of how the Fosseway Remote Bleeders are Connected to the Rear Calipers
Alex
Old Aug 12, 2020 | 05:30 PM
ChrisHarley2008's Avatar
I just installed another very similar brand. They have a threaded fitting that simply screws into the hole where the original bleeder was originally installed.
very simple, and worked flawlessly.
Old Aug 12, 2020 | 05:56 PM
jal1234's Avatar
What brand, from where?
Old Aug 12, 2020 | 06:12 PM
Old Aug 12, 2020 | 06:20 PM
Hi Chris Harley
Cheers for posting that very useful piece of information
Alex
Old Aug 12, 2020 | 06:27 PM
jal1234's Avatar
Thanks, Chris.
Old Aug 12, 2020 | 08:12 PM
You’re welcome. I have to say it was the easiest bleed from a totally empty system I have ever done. 6 pumps of the brake and done. Fabulous!
Old Aug 13, 2020 | 02:20 AM
Greg in France's Avatar
OB
The Fosseway ones are the top, superb quality fittings, large diameter remote sprung loaded one person bleeders etc etc. One of the big advanages of them is tht you never have to unscrew the nipple from the caliper again, so rusty threads, cross threading, armfuls of brake fluid, etc etc all in the past! As you can see if you look closely, I protect the remote bleeders with a bit of inner tube rubber cable tied over them. This protects the bleeders from salt, stones etc etc. Pics herewith:
Old Aug 13, 2020 | 03:34 AM
Hi Greg
Cheers!
That's the Perfect Picture!
Exactly what I wanted to see, so now I'm on the lookout for some Brake Hoses like those that I can adapt to try and make my own remote Brake Bleeder, if any one knows of any aftermarket hoses that will fit from another Car
Two of the Shorter ones would be okay, as I don't mind walking round to the other side of the Car
Which should be 'Slightly Easier' than having to jack the Car up!
So the Search is on Guys, a Brake Pipe at least one foot long (X2) with a 'Banjo' fitting on one end and a screw in for a Bleed Nipple on the other, if anyone knows where?
Old Aug 13, 2020 | 05:02 AM
OB
Go to a motorsport specialist, eg Merlin Motorsport, and they can make them up as required.
Old Aug 13, 2020 | 05:12 AM
Hi Greg
Cheers!
I will do that
1992weezer
Feb 12, 2018 11:23 AM
05XK8cfe
Nov 4, 2014 07:53 PM
rolexmike
XJ40 ( XJ81 )
Oct 20, 2010 09:40 PM
