Front Subframe rear mount - thermals
Old Sep 9, 2025 | 03:06 PM
BenKenobi's Avatar
Default Front Subframe rear mount - thermals
Whilst re-instating the exhaust downpipes they seem disconcertingly close to the rear mounts on the front subframe.
I note in the parts book that Japan actually had heat shields but that is the only country they are listed for.
I plan to provide some sort of thermal barrier but wondered what others here have done - anything - nothing ?
Not decided what I'm going to use yet but I am going to use something
Old Sep 9, 2025 | 09:17 PM
RGK20m3's Avatar
My US market ‘88 came with them, wouldn’t be hard to bend some up from aluminum sheet.
Old Sep 9, 2025 | 10:30 PM
nickr76's Avatar
Which downpipes are you fitting? The originals or something else?
Old Sep 10, 2025 | 12:21 AM
Greg in France's Avatar
Presuming OEM exhaust and no cats, waste of time, Ben. My car is driven hard and has been for years. Rear mounts pefect.
Old Sep 10, 2025 | 04:12 AM
BenKenobi's Avatar
I found a C45368 in the US and ordered - very much NLA here in Europe - but I'll have a pattern to make some if I feel so inclined - I can't get my fingers in the gap between down pipe and mount on the drivers side which is what triggered the brain cells.
Old Sep 10, 2025 | 07:17 AM
Doug's Avatar
Some exhaust wrap in the area seems like an easy solution. Lots of brands and types to choose from
Exhaust Heat Wrap - Heat Shield Wrap | Heatshield Products
Old Sep 10, 2025 | 12:15 PM
nickr76's Avatar
Are these factory catless downpipes or aftermarket? My experience with the aftermarket set I tried was terrible, they were practically touching. There was no way to make them fit that would meet my expectations. Originals went back on.
Old Sep 10, 2025 | 12:26 PM
BenKenobi's Avatar
These are rather expensive stainless aftermarket items no Cat, part of a larger bore front to back system with no centre boxes. The originals won't be going back on given what I spent on manifolds and exhaust (more than many pay for a whole XJS) - so the mount needs to suck it up - I will protect it using some method, not decided on the exhaust wrap or other methods. I can't afford the temperature in the downpipe where it meets the straight pipes to get past 1030°C - needs to stay below that preferrably 930°C or so due to the presence of a Bosch LSU 4.9 wideband lambda - all part of the plans and the project - just hadn't figured for the proximity of the mount.
I already have the starter (a WOSP unit) wrapped in a CEI blanket.
Old Sep 10, 2025 | 01:27 PM
Apologies to Doug, but i do not think exhaust wrap is advisable. Apparently, somehow, it ruins even stainless pipes rather quickly. OK for race cars, but not for everyday ones.
Attached a photo of the RHS downpipe with the V mount in the background. They are miles apart on my car, I think your aftermarket pipes are wrong, Ben. Why not get someone to cut and shut them, using your old ones as a template?
See ringed in red.
See ringed in red.
Old Sep 10, 2025 | 01:42 PM
BenKenobi's Avatar
Definitely a bigger bore but they fit fine - your mount looks oddly further forward than mine - I don't have any protection on the rack at the minute. I'll get a pic at the weekend but there will be no more squirrels chased or arms and legs allowed on this project which is becoming one of the trials of Samson
How much space do you have where the pipe crosses the mount - would be nice to get a pic looking at the pipe and the slope of the mount where it sits on the subframe
Old Sep 10, 2025 | 02:11 PM
Right now the old girl is hors de combat as i am struggling to weld up the LHS front jacking point. I'll look though the achive to see if there is a suitable photo, if not allow a couple of weeks before i can get her on the lift.
Further to the above, I have dug up this pic, and it shows how much I can remember! The downpipe looks quite close to the inside rear corner of the V mount. I will have a look at the car tomorrow and report back.
Old Sep 10, 2025 | 02:23 PM
BenKenobi's Avatar
I don't envy you - my wee beastie is only just going back together after such fun - remember this ...and what it turned into ....
Old Sep 10, 2025 | 06:13 PM
nickr76's Avatar
Are these the Simply Performance units? Thats what i have as garage decorations now. Rest of the exhaust fit great, the downpipes were off.
Old Sep 10, 2025 | 06:15 PM
BenKenobi's Avatar
They are indeed
Old Sep 12, 2025 | 08:00 PM
EcbJag's Avatar
@nickr76 Interesting. I had fitment issues with the SP downpipes a few years ago and assumed it was down to partially collapsed engine and subframe mounts causing them to rub. My car has yet to go back together but now I'm wondering if there was more to it than that.
Old Sep 12, 2025 | 09:36 PM
nickr76's Avatar
I had issues, neither side fit well. They were way too close to the body
Old Sep 13, 2025 | 03:12 AM
BenKenobi's Avatar
And that is precisely my reason for starting this thread, so I guess the next question would be what did you use as an alternate because they're in no danger of touching the body at all and if I heatshield the mounts I think I'll run with them - treat them as if they were cats - which perhaps they were modelled off.
I will take some pics today and send to Ben to see what he thinks but to be honest I am more likely to just roll with them.
So looking at Gregs pic and one I just took shows a similar scenario, and Gregs isn't the same downpipe, perhaps I didn't notice this when tearing down, either way it is staying. And yes I know I messed up my paint - the RH downpipe is an absolute pig to get in without dropping the steering rack. I also know the heat shield isn't installed on the left but thats because I am replacing the engine grounds - not happy with the originals - too stiff and too close to power steering hoses so I will relocate them - stuff ordered but not yet here.
Old Sep 13, 2025 | 11:41 AM
nickr76's Avatar
How is your transmission mount? Any sag there? If its lower than spec, i assume these would sit lower than they should.
I have the factory catted pipes, there is miles of clearance, the cat portion is much lower down.
Old Sep 13, 2025 | 12:30 PM
BenKenobi's Avatar
Is as new or better like everything else under the car - every nut, bolt, bush, spring ...... only thing I haven't replaced is the body they're bolted too, for sure it was sagging a lot when I started - front subframe has been rebuilt from the ground up, transmission mount and rear end including subframe, diff, output shafts, outer hubs, getting on for 5 years of cussing and crawling around, one setback after another but in too deep to back out.
So afraid not wish it were so easy.
Old Sep 13, 2025 | 01:58 PM
nickr76's Avatar
I had same experience, everything as new on mine as well. Odd though because they have been selling these for a very long time and I was told no fitment issues.
