Fuel pipe olive
Old Nov 25, 2020 | 01:26 PM
brinny's Avatar
Default Fuel pipe olive
Can anyone tell me the size of the olives in the compression fittings in the boot fuel pipes please . 89 v12. Many thanks
Old Nov 25, 2020 | 02:15 PM
Greg in France's Avatar
The pipes exiting the boot, Brinny? They are imperial sizes, and are still obtainable, best to accurately measure the o/d of the pipes, but metric olives will not work, even if they look close enough.
Old Nov 25, 2020 | 02:38 PM
brinny's Avatar
Thats em Greg. Return in and feed out. I will have a measure thanks.
Old Nov 26, 2020 | 12:57 AM
They will be 5/16th or 3/8th I am pretty sure. Treat yourself to a nice assortment!
Amazon Amazon
Old Nov 29, 2020 | 05:55 AM
brinny's Avatar
I'm convinced I replaced these with new at the time Greg. I don't fancy stripping them back down now the carpets in and I'm not even sure they are my problem. What about if I try giving them one final nip and then a smear of something to make sure nothing can escape? Can get to the bottom of this fuel smell. Its minor but irritating.
Old Nov 29, 2020 | 11:16 AM
RJP expoxied his corner joints, that is the definitive solution! It would be worth checking the locking rings are tight to their stops (I presume you used new ones?). Also what is the situation in the top RH corner where the cannister and rochester valve are? There are loads of tubes and clips in that area.
By all means try a nip, but before so doing, i find that my nose is the best leak-finder. If you get your nose right into that corner, if there is a small you will know it straight away. On my car i suffered a gradual increase in fuel smell from none to "maybe? to it's there" over the last two years. I renewed the 1/2 inch pipes to the sump tank and from that to the pump, plus epoxied the tank exit (later cars did not have an olive there) anf now it is back to no fuel smell.
Old Nov 29, 2020 | 11:50 AM
brinny's Avatar
Cheers Greg. Didnt know the locking rings needed to go upto a stop. I just thought they needed to be under all the tabs so will check.
yes used new.
Old Nov 30, 2020 | 12:16 AM
My experience is that after a bit the rubber ring gives a bit, and then the rings need locking up to their stops.
Navionsam
XK120 XK140 XK150
Oct 22, 2020 12:43 PM
Qvhk
May 19, 2017 12:16 PM
x300killer
Apr 21, 2012 04:22 AM
