Fuse location for factory alarm -‘94 AJ6
Does anyone know which fuse works the factory alarm system? My key fob stopped working (it has a new battery) and I’m not able to synch it to the system. I had just successfully synched the fob to the system last week and the alarm worked perfectly. Now the key fob doesn’t activate the alarm and I’m unable to re-synch it. The alarm system just isn’t responding. My service manual and owner’s manual don’t reference a fuse for the alarm.
The only thing I’ve done that may have caused this is I removed fuse #7 to the auxiliary fan to test it. The fuse was fine and I put it back in. I also removed fuse #4 to inspect it and put it back. These are the fuses on the left side of the engine bay.
Thank you
Thank you
JagRepair.com - Jaguar Repair Information Resource has all the electrical diagrams you’ll need for your car.
consider downloading them today.
Be aware that the car will not start if that fuse is removed.
You can start the engine and then remove the fuse, the engine will continue to run but must be replaced to restart the engine if shut down.
