Fuse location for factory alarm -‘94 AJ6
Old Aug 30, 2023 | 07:39 PM
XJDanny's Avatar
Default Fuse location for factory alarm -‘94 AJ6
Does anyone know which fuse works the factory alarm system? My key fob stopped working (it has a new battery) and I’m not able to synch it to the system. I had just successfully synched the fob to the system last week and the alarm worked perfectly. Now the key fob doesn’t activate the alarm and I’m unable to re-synch it. The alarm system just isn’t responding. My service manual and owner’s manual don’t reference a fuse for the alarm.
The only thing I’ve done that may have caused this is I removed fuse #7 to the auxiliary fan to test it. The fuse was fine and I put it back in. I also removed fuse #4 to inspect it and put it back. These are the fuses on the left side of the engine bay.
Thank you
Old Aug 31, 2023 | 05:03 AM
malc4d's Avatar
Right rear fuse panel nr 11 orange 7.5
Old Aug 31, 2023 | 02:06 PM
equiprx's Avatar
On my 94s all the fuses were identified on the inside of the fuse box cover.
Old Sep 2, 2023 | 08:05 AM
Vee's Avatar
Vee
JagRepair.com - Jaguar Repair Information Resource has all the electrical diagrams you’ll need for your car.
consider downloading them today.
Old Sep 3, 2023 | 07:47 AM
XJDanny's Avatar
I had completely forgotten about this great site. Thank you for reminding me. I just bookmarked it.
Old Sep 3, 2023 | 07:52 AM
motorcarman's Avatar
Be aware that the car will not start if that fuse is removed.
You can start the engine and then remove the fuse, the engine will continue to run but must be replaced to restart the engine if shut down.
Defender99uk
Mar 12, 2022 12:04 PM
Simon99
Oct 10, 2019 08:14 AM
kevy1
Jul 7, 2017 05:18 PM
Wendellr9734
Oct 28, 2010 06:30 PM
Andrew Harper
Oct 12, 2010 03:09 PM
