It Happens
Old Apr 30, 2019 | 10:35 AM
Gunner77's Avatar
Default It Happens
Well she finally suffered from the Harmonic Balancer delaminating problem. So up she goes, and will get started this week on getting it off! My question is besides using the motor what is the easiest way to actually remove the bolt on the Harmonic balancer?
Jeremy
1991 XJ-S V12
Old Apr 30, 2019 | 12:08 PM
orangeblossom's Avatar
Hi Jeremy
Although I can't answer your question, I am fascinated as well as a tad mega envious of your lifter, please could you tell me what make it is and also how you find it for working on your XJS as I think I need one in my life
Old Apr 30, 2019 | 12:15 PM
Gunner77's Avatar
HI Orangeblossom,
The lift is made by Quick Jacks, www.quickjacks.com. They are incredible for working on any vehicle, as we all know the hardest thing is getting the car up in the air to do anything (Oil Change, Brakes, suspension etc....), well these things are amazing! They are hydraulically operated and very safe to use (never had them collapse or a car drop). Can be setup and operated to lift a vehicle by one person. They are portable (I use them to life my Dodge Ram W250 Diesel) in my driveway as the truck will not fit in the garage. They provide enough clearance for one to get completely under the car to do any repair or maintenance one would need to do. Since having them I am not sure how I ever survived without them to be honest with you.
-Jeremy-
Old Apr 30, 2019 | 12:34 PM
Many Thanks Jeremy
I will check it out
Fantastic looking Car BTW
Thanks Again
Alex
Old Apr 30, 2019 | 12:40 PM
Gunner77's Avatar
Alex,
Cheers mate! She is a beauty as is all of the XJ-S's. Something classic about these cars is what draws people to them!
-Jeremy-
Old Apr 30, 2019 | 12:49 PM
XJ6Paul's Avatar
Originally Posted by Gunner77
HI Orangeblossom,
-Jeremy-
Good luck with the harmonic balancer. I think I have the same issue to address on my XJ12 so look forward to updates.
I think the correct link for your lift/jack is quickjack.com. I've looked at them before but have not purchased yet. Quickjacks.com with an 's' at the end is a different product.
Old Apr 30, 2019 | 12:55 PM
Gunner77's Avatar
I think the correct link for your jack is quickjack.com. I've looked them before but have not purchased yet. Quickjacks.com with an 's' at the end is a different product.
Dang!!!! one letter can make all the difference in the internet world! I'll keep everyone posted as I progress.
-Jeremy-
Old Apr 30, 2019 | 03:59 PM
Time-Pilot's Avatar
I've removed a bunch of them, the last time on an AJ16 XJR, but I always do it the same way. Remove the transmission inspection cover, or starter whichever you have best access to and I jam a long prybar against the teeth and the garage floor. I then bust the front nut loose with my normal 4ft breaker bar.
Old Apr 30, 2019 | 10:40 PM
Some Day, Some Day's Avatar
I've seen those for sale in my local Costco, and always wonder how resistant they are to lateral forces. I'd feel happier if they were braced at the top by connecting bars.
Mind you, they're not cheap. But I wouldn't want to buy the cheapest jack when trusting my life to it....
Old May 1, 2019 | 05:39 AM
Gunner77's Avatar
I have never had a problem with any lateral forces and I am comfortable being underneath the car while it is on the lift. The biggest thing to remember with this lift system is to ensure that the jacks are even with each other. Also there are safety latches that are a physical barrier if the hydraulic pressure fails.
-Jeremy-
Old May 1, 2019 | 06:59 AM
I've seen a few videos by the makers demonstrating their stability, and I guess jack stands don't have a much larger footprint either.
Old May 4, 2019 | 02:09 PM
71 MKIV's Avatar
not to derail the thread, but the QJ has its drawbacks.
Remember to leave room behind your car as it will shift back about 18 inches. don't ask me how I know this.....
and it looks to me that the XJS will still fall on its nose if you pick it up this way to take the rear sub frame out.
Old May 6, 2019 | 06:00 AM
Gunner77's Avatar
Well considering I can read (and do it quite well) I know that you have to leave room behind because the manual says you need to! and obviously if I needed to do anything major like pulling the rear sub frame then yes I have the intelligence to either use a proper lift (which I have) or rebalance the car on the QJ.
Boztron
Aug 8, 2012 01:24 AM
Qgregg
Mar 27, 2012 04:38 PM
Arbus
Jan 4, 2012 05:39 PM
Innovative Detailing
Detailing / Car care
Feb 19, 2010 04:01 AM
Master Deep
Sep 13, 2008 03:29 PM
