Harrison/GM A6 or Sanden SD5102 AC Compressor Replacement
Old Mar 26, 2014 | 09:14 AM
inertian's Avatar
Default Harrison/GM A6 or Sanden SD5102 AC Compressor Replacement
My AC compressor ate itself, so need to replace it. It's the original A6 unit that never worked great in the two plus years I've had the car.
My understanding is I can install another A6, or a compatible Sanden SD510 unit (have found new and rebuilt of both).
Been told the Sanden is smaller, lighter, and more efficient, and the A6 is larger and heavier, but has greater cooling capacity. May have to change some hoses and fittings to fit the Sanden, but may have to refresh similar things with the A6 anyway.
Advice welcome.
Old Mar 26, 2014 | 11:05 AM
Doug's Avatar
No direct experience. But I've heard only good things about the Sanden.
Also, aluminum A6 compressors are now available, brand new. Might merit some research? Besides being lighter they're supposed to be 'improved' performance (?)
Old Mar 26, 2014 | 06:18 PM
inertian's Avatar
Here's what it looks like, all I can make out on the label is "Lewisville, Texas USA", so I'm guessing its a GM product.
Attached Thumbnails Harrison/GM A6 or Sanden SD5102 AC Compressor Replacement-20140326_175620.jpg
Old Mar 26, 2014 | 07:14 PM
Doug's Avatar
Yeah, looks like a trusty ol' Harrison A6. Darn good compressor, actually, but notoriously parasitic. The design goes back to the early 60s. GM started phasing them out in the late 70s.
Old Mar 26, 2014 | 08:08 PM
inertian's Avatar
Anyone have a ballpark parts and labor estimate to switch to a Sanden unit vs installing another A6? Suppose I could always ask my mechanic.
Old Mar 26, 2014 | 09:03 PM
Doug's Avatar
Will using the Sanden require that new hoses be made? I'm inclined to think the answer would be 'yes'. If I'm right that would add a fair bit to the final bill.
Old Mar 27, 2014 | 11:57 AM
inertian's Avatar
My mechanic said he could install whichever I wanted, but the A6 was a quicker and easier job, which means less $.
Have decided to go with a rebuilt A6 from Jensen Auto (Jensen Auto Home) they've been around for a while, seem to know their stuff and get good reviews. Check out the videos in their eBay ads, shows their rebuild process.
Anyone have experience with them?
Old Mar 27, 2014 | 12:42 PM
Jim Dunne's Avatar
I' replaced the GM unit before. The dealer wanted $400, I cross referenced the Jag part number to a std GM compressor for $150. A needed break of good luck!
Old Apr 5, 2015 | 08:35 AM
mr.fixit1's Avatar
I know this is an old post but I figured I was reply anyhow. I just installed the new style a6 compressor on my 84 xjs yesterday and wow it is awesome, half the weight and smaller in diameter. I purchased from rock auto I will have to post some pics of the install. There are small differences where the hoses connect so I had to modify the cruise bellows bracket to make it fit but all I had to do is drill one hole to make it sit lower as the hose connection ports are slightly higher than the old compressor. Here is a link to it on rock auto https://www.rockauto.com/catalog/mor...nid=429&jpid=1
Old Apr 5, 2015 | 11:53 AM
malc4d's Avatar
I just had mine and the dryer replaced last week. I will look and see what they fitted. Also had to have it changed to 134a which I've heard doesn't cool as much...will see.
Old Apr 5, 2015 | 12:55 PM
86jag's Avatar
I was looking at replacing my A6 with the aluminum version as well. I am curious what the mods looks like that you had to do.
-Scott
Old Apr 5, 2015 | 05:56 PM
mr.fixit1's Avatar
-Scott
Well the only mod I really had to make was for the cruise control bellows mount, I wish I had taken a pic but all I had to do was drill a hole above and to the left of the stock hole so the bellows would sit in the stock location, otherwise it would not fit under the fuel rail. The other mod was just the mount for the high side bracket that normally bolts to the top hole in the compressor, I just bent it and then bolted a small piece of metal to it to extend it down, in the pic it is not there because I did it after I took the pic. As far as the mounts to the engine no mods are necessary. I also replaced the expansion valve and dryer and I charged it with this:R134a Replacement Refrigerant with Dye Can Details and Online Ordering at Enviro-Safe, Inc it works better than 134a for r12 cars and runs at lower presures too.
Old Apr 5, 2015 | 07:44 PM
sidescrollin's Avatar
To be frank, the A6 is a freaking tank. Get a new or rebuilt one and you will be fine.
Old Apr 5, 2015 | 08:55 PM
mr.fixit1's Avatar
Yes they are very good and just about indestructible, I just wanted to try out the new ones since my old a6 was leaking from everywhere. I am keeping the original and will probably reseal it and save it just in case the new one doesn't hold up. It will still be no problem to pop it back on.
Old Apr 5, 2015 | 09:01 PM
JTsmks's Avatar
Be very careful with the replacement one. It says it has Teflon, that's the number one reason the Fx15 and FS10 ford compressors suffer the "Black Death". The Teflon melts when the compressor goes south and goes through the whole system. The other problem is if one piston goes south the rest keep churning and the Teflon gets through everything. If you hear anything unusual out of that new compressor, pull the plug on it and get it out of there. Hopefully she runs long and strong for you.
Old Apr 5, 2015 | 09:18 PM
mr.fixit1's Avatar
Yep, I am familiar with that problem, I own a Mercury Marauder and the compressors on those are know for that problem. Luckily mine has never done it, but I think a lot of people will keep running the air conditioner even if the compressor sounds like an old sewing machine..lol
Old Apr 13, 2015 | 09:03 PM
86jag's Avatar
Looks like the aluminum version is a different compressor with add-on adapter plates to make it work in the same spot as an A6. Looks good.
Many Thanks!!
-Scott
Old Jul 13, 2015 | 01:37 PM
Dymaxxion's Avatar
I'm very curious about this, as I am also trying to charge up my AC system. Is this particular refrigerant a drop in replacement for R12? Are any parts (like upgraded O-Rings) needed other than the expansion valve and Dryer? Where did you get the valve?
Old Jul 13, 2015 | 06:19 PM
JTsmks's Avatar
There are no current "drop in" replacements for R12, people love throwing that claim around, especially refrigerant manufactures! Read 11 on the link.
http://www.epatest.com/faq/609/
Old Jul 13, 2015 | 07:43 PM
Dymaxxion's Avatar
EPA 609 Certification - FAQ
Bummer. What would it take to get R134a in my system? I've been looking all over the place but can't seem to find a straight answer. There is no refrigerant in my system currently. Something I'd like to remedy in this 90+ degree Oklahoma heat.
