Has anyone sourced standard 5.3L piston rings? '90 XJS
Old Jan 27, 2020 | 05:10 PM
grantp's Avatar
Default Has anyone sourced standard 5.3L piston rings? '90 XJS
Hi Folks. Decided to do an engine /trans out on my 1990 convertible - mostly to perform cosmetic work on the engine and engine bay (including all new fuel lines and hoses - and track down a few electrical gremlins), but am looking at an engine refresh while it is out. I can source gaskets, seals, crank and rod bearings, but am having trouble finding a source for standard piston rings. Low mileage engine, but it has been sitting for a while. Cylinder cross-hatching still visible, but want to refresh while I'm this far in - virgin engine. Any leads?
Old Jan 27, 2020 | 05:40 PM
ronbros's Avatar
best piton rings i have EVER used , many times ,, TOTAL SEAL piston rings,(google).
ron
Old Jan 27, 2020 | 06:09 PM
Jagboi64's Avatar
Here are 2, only 10 more to go....
https://www.ebay.co.uk/itm/JLM1789-P...-/380840387701
Or look for Hastings part # 2C4441
https://apaengineering.net/HastingsC...partdetail/306
On an engine where you are doing a refresh rather than a full rebuild I would not use the total seal style. I've seen too many failures after using those.
Old Jan 28, 2020 | 01:53 AM
Greg in France's Avatar
https://www.welshent.com/Jaguar-53L-...rd-P11537.aspx
they are around, lots of specialists in the UK eg Rob Beere..
Old Jan 28, 2020 | 04:18 AM
grantp's Avatar
Nice folks! Thank you!
Old Jan 28, 2020 | 06:13 AM
Robert Laughton's Avatar
Hi Grant,
I'm in St Catharines, and have a V12 stripped down, others for parts, and cars. I have a new timing chain tensioner, good heads etc.
Maybe I can help if you run into a problem. Good luck,
Rob 905-932-0284
Old Jan 28, 2020 | 08:15 AM
xjsv12's Avatar
ron
SearchByPartno
https://www.summitracing.com/parts/tsr-c1444
slightly overpriced
https://www.ebay.co.uk/itm/FOR-JAGUA...T/193046965618
I suggest this is a good deal.
Old Jan 28, 2020 | 02:03 PM
grantp's Avatar
Originally Posted by xjsv12
ronbros - Your ebay link was great - thanks!
Old Jan 28, 2020 | 02:32 PM
ronbros's Avatar
also you get what you pay for, quality takes a lot of engineering and time!
ron
Old Jan 29, 2020 | 12:46 AM
VancouverXJ6's Avatar
Rob Beere has alllll the v12 goodies if your pockets are deep.
Old Jan 31, 2020 | 09:44 AM
grantp's Avatar
Thanks Robert - I'll keep your number handy!!
jesus perez
May 7, 2019 08:46 PM
Daim
Oct 7, 2016 06:21 AM
superchargedtr6
Jun 21, 2015 11:32 PM
sidescrollin
Nov 17, 2012 05:33 PM
Iguana
Sep 7, 2008 07:58 PM
