Headlamp Powerwash Jet Covers
Old 12-09-2018, 08:27 PM
Vee's Avatar
Vee
Vee is offline
Received 1,512 Likes on 1,177 Posts
Default Headlamp Powerwash Jet Covers
OK, I've snagged all the large parts needed to repair the front end of my 1996 Jaguar XJS. It's the little guys that are gonna kill me.
We all know the chrome headlamp jet washer covers are difficult to find. I am missing the passengers side cover. Is there an alternative way to make do without the covers? I know there are blades without holes for these washers, which are equally difficult to find. Has anyone else found a way to cover up the holes without it looking strange? I'm just wondering if there are any other solutions to this problem.
Thanks.
Old 12-11-2018, 12:25 AM
Jagboi64's Avatar
Received 3,071 Likes on 2,039 Posts
I'm thinking the best method might be to get an existing cover scanned and then have it 3D printed.. I need a left side jet and cover after my 94 was hit last year, and no luck finding any.
Old 12-11-2018, 03:02 AM
rgp's Avatar
rgp
rgp is offline
Thanks.
according to jdht web parts the rh one is still available newfor around 15.00 DAC7928 and the rh jet is on ebay from black country jaguars DAC7930
Greg in France (12-11-2018)
Old 12-11-2018, 05:18 AM
Vee's Avatar
Vee
Vee is offline
Thanks. I didn't realize it was still available from JDHT! I did buy one from Black Country Jag for about the same amount.
As for the jets, I have glass headlamps. Hot glass and cold water don't work well together. I pulled the fuse from those jets because I suspect it's been the cause of a cracked headlamp in the past.
Thanks for the help. I think I'm just about done! Car goes in tomorrow to get the radiator support welded back in, then the car gets put somewhat back together, then off to get repainted!
Old 12-11-2018, 11:58 AM
Jagboi64's Avatar
That's the 5.3 non facelift parts, up to VIn 188104. His signature says a 1996 car, which is the facelift parts which are NLA.
Old 12-11-2018, 01:38 PM
rgp's Avatar
rgp
rgp is offline
according to what I see they are DAC
XJS from (V)179737 to (V)226645 models
i
Old 12-11-2018, 01:57 PM
Jagboi64's Avatar
i
Need to drill down a little bit further in the listings to see the VIN break.
Old 12-11-2018, 02:26 PM
rgp's Avatar
rgp
rgp is offline
Ah. Thought that was just 6lt
Old 12-23-2018, 05:29 PM
Vee's Avatar
Vee
Vee is offline
Well, I got the part...its undoubtedly different. It's smaller, and made of metal. The original part I had was made out of plastic.
Is there a way to mount the new part, even though it's not the right part? It won't mount the way it was designed, I'm wondering if theres some kind of putty I could use to mount them. This new one is way heavier than the originals for my car. I guess I should invest and buy the right hand side so they match?
Any mounting suggestions out there. The spray jets will be disabled, so it's for aethetics only.
Thanks.
macudc
04-26-2020 12:35 PM
quartetchiang
08-09-2017 09:48 AM
JarodL
04-21-2015 02:47 PM
Stu 1986
03-27-2010 06:24 PM
Quick Reply: Headlamp Powerwash Jet Covers
