how do I bench test dash gauges with multi meter
Old May 30, 2021 | 06:32 PM
RagTopJag's Avatar
Default how do I bench test dash gauges with multi meter
I have taken my gauge cluster out of my 86 XJS V-12 to repair my gauges that don`t work for one reason or another and a cleaning. How can I bench test these gauges themselves with a multimeter before reinstalling them to make sure they work as they should. Is there a schematic for the ribbon on the back of the gauges so I can test those circuits also. Thanks in advance
Old May 31, 2021 | 12:41 PM
JayJagJay's Avatar
If you do some google work and search xjs instrument cluster diagrams a few things will come up, but mostly what I've seen are images made by folks here and they don't really get into a lot of specific info about resistance, amperage and voltage and what makes the needles tick in the cluster. BUT the images do give an idea of which tabs in the connector/plug drive which functions in the cluster.
For the gauges the way that current/information is delivered from the ribbon to the individual gauges is important and are fiddly. Basically there are screws and bolts, with tiny washers, that carry current/information driving the gauge. The screws and bolts make a pressure contact with the ribbon on the outside of the cluster, then the treads of the screws/bolts run into and on plates in the individual gauges delivering the signal. CAREFUL removal of the screws and bolts, cleaning of them and cleaning of the plates in the walls of the individual gauges will sometimes help.
If you are more technical and knowledgeable on electrics than I am (and most people here are) and start deriving values from the gauges you have and what they SHOULD be from another source I think that would be a great set of and contribution to the forum. It's very possible that it exists and is already in the forum, but I ain't never seent it, lol...
Right now I'm dealing with an speedometer (or 2) that doesn't work. At rest, car started, it's getting B+ voltage where it should (green wire from memory) 1.5v in P, wheels not spinning, at the 2nd of the 3 and a good ground at the 3rd pin on the back of the gauge.... and the speedometer doesn't work. I don't know WHAT the values in the wire that provides the information should be, I wish I did...
For me, one of the problems is fear. The ribbon is so fragile, quarters for accessing the back of the panel when connected are so tight that a FEAR of doing more harm than good - crating a short and or damaging the panel - prevent me from doing anything like trying to take measurements while the thing is installed.
Anywho.
Old May 31, 2021 | 12:52 PM
JayJagJay's Avatar
I don't know if this helps.
Old May 31, 2021 | 08:35 PM
RagTopJag's Avatar
Thanks JayJagJay, I can certainly use the schematic to some extent. I know what you mean about the ribbon being fragile and I would definetly recommend anyone doing this to study the ribbon and screws and to take your time, watch the ribbon while you loosen the screws to make sure the ribbon doesn`t twist under the screw and have a few different screwdrivers handy, if one doesn`t fit tightly in the screw head try another and another and another until hopefully you`ll find one that fits tight, and don`t strip the head out or there could be more trouble removing it. If the ribbon starts to move with the screw, tighten and loosen working them until you can get them moving without bringing the ribbon with it Mine were rusted and though they screw into plastic some of them were a real bear to get out. I managed to save the ribbon in my parts cluster because I screwed up the original not following my own advice and even broke some of the plastic where the screws screw into. From my parts cluster I`m using the plastic shell because that one is good and the ribbon which I managed to remove without damage because I screwed the old one up. I can`t even move the needles on my parts gauges but my originals at least move so I`m hoping they test okay. I will just see if they work, though I don`t know how accurate they will be, at least they are freed up. I`m assuming that the ribbon I screwed up is the reason for them not working. I`ll post how I make out. Thanks for the info. Rod
Old May 31, 2021 | 08:39 PM
RagTopJag's Avatar
__________________
Old Jun 1, 2021 | 06:27 AM
Vee's Avatar
Vee
If it were me, I'd do a simple continuity test at both ends of the ribbon, and then test the gauges directly, since all of the posts will be easy to get to.
I assume you have the electrical drawings for your car? JagRepair.com - Jaguar Repair Information Resource
That should help you figure out what is supposed to see what.
Old Jun 1, 2021 | 08:13 AM
JayJagJay's Avatar
I have the XJS and 2 XKs... There are things I worry about when considering longevity and the future with these cars and some of their components... The XJS, for one (and I really can't think of much else at the moment) it's that ribbon. What's going to happen when they/it finally does fall apart and lose its ability to do it's job? Maybe, someday, some company will produce a replacement... A replacement that doesn't cost 1000000 dollars. Mine is in pretty bad shape.
Old Jun 1, 2021 | 09:05 AM
RagTopJag's Avatar
Default Bench test gauges.
Checking the ribbons continuity is on my list. Mainly to see if I have gotten the ribbon ends clean enough to make a good connection. I scuffed them lightly with 220 grit sandpaper not wanting to go overboard but not so little as I have connection problems. The steel connectors on the bulbs raised havoc with the copper ribbon ends. I managed to clean them without ruining any , so far. Thanks for the advice.
Old Jun 2, 2021 | 06:47 AM
richardsjags's Avatar
I made the instument cluster diagram shown in this post many years ago when overhauling the cluster in my pre HE coupe.
I also pulled the cluster out of my 88 convertible at the same time and noted the electtronic speedo mod.
Part of the reason was to put LED turn indicators in both clusters where I can actually see them.
As for the flexible printed circuit, they can be made cheaply in China. I know that becasue in my factory we get all our PCBs madei in China.
Top quality, 7-10 day turnaround incluuding UPS down to Oz. My guess is US$15 each landed here if I order about 20.
I don't have time to mess around and make the artwork. Anybody does that and sends me an Altium copy or Gerber filkes I can get a price
I could check if China can plate the connectors with gold too, unlike the bare copper ones in the OEM version.
Old Jun 2, 2021 | 07:44 AM
JayJagJay's Avatar
Hi Richard... I'm all kinds of interested...
So, what would one have to do to start this process... Would our ribbons need to be sent to china for the copying?
Would you be willing to start an individual thread offering the possibility of a new ribbon/circuit board?
Old Jun 2, 2021 | 07:45 AM
JayJagJay's Avatar
I guess I don't understand the Gerber fikes or Ultium ideas. I'll do some googling... Please let me know what to do
Old Jun 2, 2021 | 07:58 AM
JayJagJay's Avatar
I mean, if a circuit board could be produced where male and/or female plug ends were possible instead of the friction/pressure type connections, that would be amazing!
Old Jun 4, 2021 | 07:13 PM
RagTopJag's Avatar
Richard I would be interested in the new circuit board also. I have it cleaned up and installed and it looks as though it will work with key on but I`m still waiting for the parts to get my XJS V-12 running so I can`t test all connections yet. I`ll be watching for further information. What do you mean by the artwork. The colored paths.
Old Jun 4, 2021 | 07:39 PM
An artwork looks like this.
( The screen says pdf file attached but I do not see it displayed )
File Type: pdf
Old Jun 4, 2021 | 07:57 PM
JayJagJay's Avatar
Hey Richard... Mannnn, this could really be a big deal. It's a needed thing. Are you really in the know about getting this done? It would help a lot O folks...!
adenshillito
May 14, 2021 09:26 AM
Waz
Nov 25, 2020 10:50 AM
gailsluck
Feb 6, 2019 08:40 PM
Sean W
Sep 3, 2018 03:46 AM
vh-atr60
Feb 28, 2014 04:18 PM
