how to run a 6cyl tach off a 12cyl motor
Old Feb 25, 2013 | 11:08 AM
calvindoesntknow's Avatar
Default how to run a 6cyl tach off a 12cyl motor
i know this has to be able to be done, since people run 4cyl tachs of 8cylinder motors
does anybody have any insight?
Old Feb 25, 2013 | 05:11 PM
Everything is do-able, eventually.
The tacho would need the "pules signal" trickery inside reworked/replaced/fiddled to accept the 12 pulses versus the 6.
An instrument repair mob would do that for a fee.
Old Feb 25, 2013 | 07:57 PM
Im actually looking to make thir run a 6cyl efi system
Old Feb 26, 2013 | 04:25 PM
warrjon's Avatar
Easy on the Marelli just run off 1 coil.
Cal are you going to run the car distributorless? if so you will use 2x6cyl ignition units just run the Tach off 1 side.
Old Feb 26, 2013 | 06:05 PM
billsautoworks's Avatar
I know on aftermarket tachs, there is a switch inside to change, marked 4-6-8. John's cars in Dallas does the factory tachs when you buy the small block chevy conversion kit from him, so it can be done. I am not sure if he would tell you how to do it if you called him or not.
Old Feb 27, 2013 | 08:21 AM
MustangSix's Avatar
If you are using a single distributor you can attach a tach signal converter from Dakota Digital to drop the pulses to what you need. Under $100.
Old Feb 27, 2013 | 12:50 PM
Mustang six im checkinf that out right now
Old Feb 27, 2013 | 02:35 PM
So it doesnr go to 12cyl. But could I just run 8 in and 4 out? Because its the same pulse adjustment
Old Feb 28, 2013 | 06:50 AM
MustangSix's Avatar
What kind of ignition system are you running? Knowing that, I might have another idea.
Old Feb 28, 2013 | 02:08 PM
Planning on ussing a pre he ignition wuth an aftermarket pickup and msd 6al box
Old Feb 28, 2013 | 10:07 PM
warrjon's Avatar
The 6al is only programmable for 4, 6 and 8 cylinders, meaning you will need 2 of them and run them 60° apart.
With the tach signal you can run a 6 cylinder tach off 1 of the 6al’s
Old Feb 28, 2013 | 10:53 PM
Huh, I talked to a msd guy and he said they are running them on he distributors. Maybe he's refering to a different model I dont remember
toronadomike
Jan 22, 2026 10:13 PM
jagtoes
Sep 9, 2015 09:56 PM
Saturbo
Sep 8, 2015 07:35 PM
1100me
Sep 7, 2015 06:26 AM
XJsc-guy
Sep 2, 2015 11:43 AM
