Hunting xjs
Welcome to the Forums.
Please do an Intro in teh New Members Area when time permits.
The list can be long, and I am assuming a Marelli car, as 1989 was teh change.
TPS out of range.
Throttle bodies way overdue for a clean and linkage reset.
PCV valve having a hissy moment, saok in paint thinners for a few hours and blow it out, you might be lucky.
Vac leaks, and that could be a days work tracking all the possibilities. Hoses, Inlet gaskets, hoses, over run valves (if fitted), hoses, etc etc.
Then comes the Marelli versus Lucas issues, and for that we need to know what system YOUR car is fitted with.
TPS out of range.
And.........?
What happened?
Could you clarify "closed my aav" ?
Grant is correct that the 'could be' list might get long, and you very well may have a stack-up of different faults that need correcting. But, the AAV is always a prime suspect so let's narrow down exactly what you done and how, and go from there.
I have had to 'synchronise' the throttles when that caused that fault.
If one is opened more than the other it causes problems.
Check for the same gap or listen to the pitch of the 'hiss' at each throttle to determine if they are even close.
bob
bob
And.........?
What happened?
What happened?
TPS out of range.
TPS out of range.
And.........?
What happened?
What happened?
I cleaned the but I never feelerd them + there’s blowing from the manifolds which I cannot hear a thing from the throttle
Remove the LH side air filter cover and the air filter itself. You'll now see the 1" hole in air filter housing that the big AAV hose connects to. With the engine running, cover this hole with your hand.
Does the up-down surging go away?
also cleaned the mucky from the butterflies and made sure all the things that should be connected is
Makes sure the throttle blades are set to the correct .002" gap. Make sure that your linkages are not holding one throttle open a bit. Left and right must be just the same or you'll get surging or other weirdness.
As Doug's hole-blocking test will discover, it just might be a stuck-open AAV. When this happens, the symptoms are exactly as you describe. This is because there is a large air intake source through the AAV. This tricks the ECU into thinking the throttles are closed and the car is coasting from high speed, so it cuts the injectors to save fuel until the revs get below about 1300, then it starts the injectors again, the revs rise and so the cycling goes on. A new or repaired AAV is the answer. It can also be eliminated - but that is something for later when you are a real XJS fanatic!
And.........?
What happened?
What happened?
The pipe goes into the manifold not the filter housing
Look t item #4 in this picture.
https://www.jaguarclassicparts.com/u...alve-5-3-litre
Your engine should have this hose. One end goes to the AAV and the other end goes to the back side of the LH air filter housing. If you remove the air filter you'll see the hole that goes to this hose
I am clearly missing something here.
"I closed the AAV", which I assumed you blocked the thing off, but it appears you only repaired the inlet hose from the air filter backing to the AAV. NOT a vac hose, just an Inlet draft hose,and has NO affect on any hunting.
"I looked at the TPS plug", interesting??????
Have a read, maybe a combination f things that need some attention.
NOW, I am betting on a jammed AAV.
