I have checked all vendors here.
Old Nov 20, 2017 | 12:00 PM
macdoesit's Avatar
Banned
Default I have checked all vendors here.
For the 12 fuel hoses with the metal crimps that connects to injectors and cannot find.
Old Nov 20, 2017 | 12:09 PM
JigJag's Avatar
Any fuel line that is appropriate for the fuel you use ( ethanol tolerant likely needed ) is fine. 8.5mm ID if I recall correctly.
The metal ferrules are available from suppliers advertising in the site.
Old Nov 20, 2017 | 12:26 PM
Jagboi64's Avatar
The "crimps" are not crimps, they are a collar that is not attached to the hose and are reusable. Fuel injection hose of the right size can be cut to length and used.
The type of fitting used on the rail and the hose is a system that is designed to be leak free with no clamp, using a clamp will actually compromise the joint.
When removing the old hose UNDER NO CIRCUMSTANCES use a knife lengthwise to split the old hose. The blade will often go through the hose and nick the barbs on the rail or injector. These nicks will cause leaks.
Old Nov 20, 2017 | 01:38 PM
brinny's Avatar
Can you give a bit more info on the collars please. I.e. Availability and type. Thanks
Old Nov 20, 2017 | 01:57 PM
Mark SF's Avatar
Don't use fuel hose with a fluorolastomer liner, like the Goodyear stuff with a blue liner. It's not grippy enough, and leaks. I did have better luck with Gates hose, no liner.
Old Nov 20, 2017 | 02:01 PM
orangeblossom's Avatar
Hi Mac
Try: Dimar Motorsports, Canoga Park California
Old Nov 20, 2017 | 03:04 PM
Jagboi64's Avatar
The ones I have seen are like a "top hat" that go over the hose at the end that attaches to the fuel rail. Part #6 in the diagram, part number EAC7876. The do not fit tight on the hose, but semi loose.
https://www.jaguarclassicparts.com/u...tors-5-3-litre
Old Nov 20, 2017 | 07:54 PM
Doug's Avatar
Google 'EAC7876 Jaguar' for the ferrules
Old Nov 20, 2017 | 08:38 PM
Andreas Schmieg's Avatar
Or try V12 Performance. Small business, sometimes takes some time.
Jaguar XJS V12 Fuel Injection Hoses and Kits for V12 Performance
Old Nov 20, 2017 | 09:36 PM
JigJag's Avatar
<Raises finger pensively with a difficult expression>
Or from or any other company, perhaps even one that consistently delivers ordered products in a timely manner. Whichever.
Old Nov 20, 2017 | 10:27 PM
Doug's Avatar
Can't go wrong here:
Jaguar Fuel Injector Service
Good service, always
Old Nov 21, 2017 | 04:31 AM
Greg in France's Avatar
Brinny
As you are in the UK, I suggest these people, who supply a full kit with instructions. Very high quality stuff.
https://mrinjectoruk.co.uk/Bosch-028...-P2420447.aspx
and this
https://mrinjectoruk.co.uk/Jaguar-V1...-P4886461.aspx
These two enables a full refurb of the injector, its filter, all its seals and pintles.
They do kits for the 6 cylinder engine as well.
Old Nov 21, 2017 | 12:39 PM
macdoesit's Avatar
Banned
I assume I need to take the fuel rail off to replace the hoses, is there anything I need to be aware of. I will also replace plugs and plugwires while fuel rail is off.
Thanks for all the replies.
Old Nov 21, 2017 | 12:55 PM
brinny's Avatar
Brinny
and this
Notes made Greg . Thank you
Old Nov 21, 2017 | 02:08 PM
sidescrollin's Avatar
Someone said not to split the hoses lengthwise, but old hoses can be extremely hard to remove. Hopefully yours aren't that bad, but the ones I have done took a lot more work than you would expect.
Old Nov 21, 2017 | 04:08 PM
Jagboi64's Avatar
Oh yes, they are not easy to remove! What I did was use a sharp hobby knife to shave down the old hose until it was very thin on the side and then it could split and come off. Takes patience to do, it won't be a quick process.
Old Nov 21, 2017 | 04:47 PM
rgp's Avatar
rgp
I cut the injectors off and burnt the stubs on the rail with a gas lamp the injectors i bent the collar down and used a blade to split them.
I googled it and came up with 4 usa supplier's and same uk. One in Texas which I have used in the past for twin fans.
Old Nov 22, 2017 | 06:11 AM
macdoesit's Avatar
Banned
Bump
Old Nov 22, 2017 | 07:04 AM
Doug's Avatar
Yes, remove the rail.
Pay close attention to the orientation of the injector hold-down plates. Installing them backwards will darken your day a bit.
Order new injector seals ahead of time...the ones that sit in the inlet manifolds
I'm on my first cuppa coffee. Might come back with more.
Old Nov 22, 2017 | 11:10 AM
macdoesit's Avatar
Banned
Thanks Doug, I need all the info I can get.
Does the kit (Greg in France) post have all the parts needed ?
